New to me 206 GT | Page 5 | FerrariChat
New to me 206 GT
Discussion in '206/246' started by omgjon, Oct 1, 2010.
  1. swift53
    swift53 F1 Veteran
    8,283
    E.S.
    Alberto
    Looking good Jon!
    What is the source for the bumper rubber, Cicognani?
    I have given up on my quest for the "L" bumpers, so we are modifying
    proper bumpers to the configuration of 206/L series.
    Cut, pound here and there, weld back to the narrow version.
    Regards, Alberto
  2. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    The bumpers were a very interesting project! The bumpers were original to the car as far as I know and the rubber was very old and cracked. I ordered 206 bumper rubber from CICO but it didn't fit as it was too narrow and left space showing. This was the same rubber I used on Davids stainless steel bumpers on his 206 and the rubber fit fine. I contacted Cico and they had no rubber that was the same as the rubber I took off. I don't know if my 206 being the 18th produced might of had slighly different bumpers compared to the later 206 bumpers. I ended up modifying 246 bumper rubber and now it looks exactly like the rubber that came off. It's a conundrum!!
  3. swift53
    swift53 F1 Veteran
    8,283
    E.S.
    Alberto
    Thank you Jon, very interesting!
    How come David's car had stainless bumpers? Did he have them made, I assume, as that would not be original, right?
    Regards, Alberto
  4. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #104 omgjon, Sep 16, 2014
  5. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    We went through the same exercise, had to narrow the gap about 1/8" when welding the backing strip back in (the 206/L-series bumpers are a very different construction to M/E-series). Cicognani don't have the right stuff but we stuck with it, I also noticed the old original rubber had shrunk slightly and gone hard and theirs was basically the same size so it's possible they mastered it on the shrunken rubber...
    My car didn't have the original bumpers with it, so we found 4 original 206 bumpers, Keith found me a good pair of rears in Italy a few years ago, I found 1 front in Italy and Max sold me an extra set of rears. They were alot of work.
    Regards, Andrew
  6. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #106 omgjon, Dec 30, 2014
    The 206 has sort of been on the back burner as far as paint and body and metal work as I've been putting other cars in front of mine. Finally I've moved it in line and now with all the metal work done it's full speed ahead. Grigio Ferro Metallizzato.
  7. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    It's about time!
  8. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #108 omgjon, Jan 4, 2015
    I have a question for the 206 experts out there. My grille had no black strakes as I've seen in all other Dinos. As far as I can tell this grill has not been taken apart but I'm sure someone here can give me an answer. This Dino is the 18th.
  9. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,487
    Germany
    Matthias
    #109 GermanDino, Jan 5, 2015
    Hello Jon,
    normally the 206 GT had black strakes originally. You can never be 100% sure but I doubt your grill strakes haven`t been black original.
    Attached a picture of untouched #00116.
    Regards Matthias
  10. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Black they will be then.
  11. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #111 omgjon, Jan 14, 2015
  12. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Jon,
    Are you sure? I think polished Alloy could look really cool!!!
    Shawn
  13. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #113 omgjon, Jan 20, 2015
  14. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    Jon:
    I think that on a 206, the gas tanks are painted black. Also, I remember a cutaway of a 206 GT which had the brake calipers painted gold and not silver. Please check with Matthias or one of the other 206 owners.
    Looking great...Keith
  15. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Yes, gas tanks originally black and same through L-series.
    That cutaway drawing showed gold calipers but this was a mistake I think, there was a discussion on that a few years back. All early brakes were a more dull silver - seen on the spacer block faces after splitting them. I redid mine in clear CAD which is what the plater told me it was.
    Great project Jon, good to see it moving.
  16. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Yes, the gas tanks were black but I'm debating whether I want mine black. I always take a few liberties!
  17. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    As you should - it's your car. Keep up the great work.
    Thanks to Andrew for clarifying that the caliper finish should be silver and not gold. That cutaway diagram misled me.
    Cheers,
    Keith
  18. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    No worries, it was in the forefront of my mind as I just picked them up this morning from the platers ... again. First go around the plating reacted with contaminants in the porous casting, second time they were chemically stripped, light bead blast to close the pores, then plate a base metal, flash nickel (I think) and then clear cad. Left them for a month to make sure it didn't happen again. Not sure it's worth all the hassle compared to zinc.
    Jon, do you do these in zinc?
  19. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Yellow Cad.
  20. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #120 omgjon, Feb 11, 2015
  21. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Jon,
    Any spray outs of the Grigio Notte?
    Shawn
  22. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #122 omgjon, Mar 5, 2015
  23. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Jon,
    I don't think 206's had a paper windshield from the factory.
    Shawn
    P.S. - I can't wait to see color.
  24. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #124 omgjon, Mar 6, 2015
  25. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    #125 omgjon, Mar 23, 2015
