Newbie, just a few questions regarding my new 360 :) | Page 2 | FerrariChat
Discussion in '360/430' started by F360_Spider, Mar 7, 2011.
  1. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    any ideas how to un trigger that? i would of thought this car flys to 180, the M3 had no problems :(
  2. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Nah, you've something wrong if she wont pull cleanly to red line. Short of traction control kicking in the engine should rev out freely.
    The fact that the slow down light lit up will hopefully have registered a fault which Verdi will be able to read with the diagnostic equipment.
    Good luck and be sure to post the cause and solution.
  3. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    they were meant to contact me this morning and pick up my car up at 10:30 but havent heard from them yet..
  4. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    #29 F360_Spider, Mar 9, 2011
    cars gone in to them, they will diagnose and give it back to me then i will book it in for repairs another day.. ill keep you posted.
  5. Chiaroman
    Chiaroman Formula 3
    1,679
    New Jersey
    Why not let them keep it, sort it out AND repair it?
    If something is amiss it should be taken care of before it becomes catastrophic.
    Again...as always...just my 2¢
    Yours,
    Tom
  6. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    this is what they have advised me, i was under the impression they would keep it but have advised i will have to rebook another time as they cannot keep the car overnight?
    lets see what the outcome is first, hopefully its not too bad
  7. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    i will list the faults when i get home..
  8. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    so i was told there were alot of fault and these were the main things they noted down for me, ive just typed it word from word:
    CAT CONTROL ST (R/H)
    LOWER MULTIPLIER VALUE LOW (L/H)
    BATT VOLTAGE HIGH (POSSIBLE ALTERNATOR)
    CANISTER PURGE CONTROL SYSTEM (LEAKAGE)
    CHECK OF PRESSURE PURGE SENSOR (---"---)
    MULTIPLE MISFIRE RECOGNITION (FURTHER INVESTIGATION REQUIRED)
    MAJOR EMISSIONS ON 3 CYLINDERS
    CAR REQUIRES A 4 WHEEL ALIGNMENT CHECKS
    - ALL ERRORS CLEARED
    The Engine manegment light is back on now
    are these major faults? should i leave the car parked up untill i get these faults resolved?
    will it damage anything by driving?
    do these sound lilke n e thing related to not having full power and struggling at 5-7 rpm?
  9. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I feel for you buddie but I'm afraid I can't give you any technical assistance.
    What I would say is that your problems might be relatively minor so don't panic! Your problem pulling through the higher end of the rev range could well be due to the engine management preventing and not be mechanical at all. If, for example, you have a faulty sensor with indicates the fault Cat Control ST that might well be something that then prevents full fuel delivery in order to prevent bad emissions etc. Additionally the one fault could well be throwing more than one error code.
    Have the shop given you a suggested course of action?
  10. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,637
    South East
    Jimmie
    #35 greyboxer, Mar 10, 2011
    You may be lucky (as little as 3 loose or faulty plug leads) with this but for example the owners manual (is it that you do not have it or just have not looked at it ?) describes the engine management light (yellow engine) as follows : When the warning light 'engine check system failure' switches on as remarkable reduction of the engine performance may also occur
    The alignment is relatively cheap as is an alternator / voltage regulator rebuild
    By the sounds of it you have not had the slow down red light yet which is probably a good thing
    It is probably best to get it booked in BUT they could be fiddly time and/or money consuming faults to resolve
    Wait & get a few more opinions here before you decide anything
  11. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    i do have the manual i will have a read through it.. the SLOW DOWN light has appeared on me before, when i am giving it some it starts flashing, mainly at high speeds aroudn 120 or 140.. i have had it come up around 90-100 as well?
  12. vrsurgeon
    vrsurgeon F1 World Champ
    16,456
    Charleston, SC
    Curt
    Hmm.. as just another peanut in the gallery... have they pulled the spark plugs? My 99 was running a tad rough but only at lower RPMs.. got the slow down light as well..
    On mine turned out to be a couple of coil packs gone bad. Might explain the hesitation and with fuel dumping into cats leading to slow down lights when going all out...
    Just a thought..
  13. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    i have always thought by changing the spark plugs and the battery this may resolve the issue but do not know how to do this myself, and i know if i ask someone to do it they will rip me off or advise me wrong and get 423534 other things done..
    the battery is not very good the previous guy has said when the last battery died he changed it out for another one which was not very strong and is weak, so that made me think..
  14. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    OK, battery is easy. Open up bonnet and turn battery isolation switch to off position. Can be difficult to turn but persevere and get it turned off. The battery is located under the footrest on the passenger side. Remove the footrest, disconnect the battery and bring it to your local motor factor. He will be able to put a test rig on it, let you know whether or not it's in good shape and should be able to provide you with a replacement from stock. You do not need a special or a "Ferrari" battery here! Standard replacement will do perfectly well.
    Spark plugs are equally easy. Four on each side. You need to remove the individual coils on top of each one and then remove with a regular spark plug spanner. If you're not happy doing this yourself order the correct replacement plugs and then bring the car to your regular (non specialist) mechanic and ask him to do it for you.
    Your regular mechanic should be able to diagnose a faulty alternator or voltage regulator also.
  15. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    #40 F360_Spider, Mar 10, 2011
    Thanks alot for the write up, something i will definatly get done over the weekend.. also i was under the impression that a HEAVY DUTY battery was needed as i have been told from VERDI's and another guy.. so that doesnt make a difference really?
    Thanks - very helpful
  16. greyboxer
    Dec 8, 2004
    12,637
    South East
    Jimmie
    #41 greyboxer, Mar 11, 2011
    Good point : presumably if OP knows which cylinders are misfiring he can swop for a known good & check that way - fairly easy to do oneself - part no 177074 sits between spark plug and ignition lead : item 2 http://www.eurospares.co.uk/parttablePopup4.asp?ID=1663483
  17. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    No, not a particularly "heavy duty" battery, just one of the same spec. !2 Volt, 65 Amp Hour, 450 Amp (peak) - pretty standard stuff.
    There are fancy alternatives out there if you want to spend extra money and/or save weight but a regular old car battery from your local motor factor will do you nicely, particularly if you use the car regularly.
  18. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
  19. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    i have started the car after a few days and i noticed white smoke coming frmo the exhausts, is this normal?
    when i first fire it up after a day or 2 it doesnt sound good when it first starts like it struggles but then it warms up and sounds ok.. but smoke is still there, is this normal?
  20. greyboxer
    Dec 8, 2004
    12,637
    South East
    Jimmie
    White smoke or condensation - does it go after 10 minutes or so ?
  21. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    I had fun with mine when I cranked it (cold start) with the Capristo valves fully open. It gave me a rude shock when I looked into the rear view mirror and all I could see was black smoke. LOL...needless to say I never did that ever again.
  22. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    i think its smoke, but could be condensation.. it does go after a while?
    the thing is condensation should only happen in very cold outdoor condistions right? i could see this hapepning when it was fairly warm?
  23. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Engine starting from cold will make white smoke (steam) for a little while - more pronounced in winter conditions generally but it will generally be there if the metalwork of the exhaust is cold.
    You shouldn't see it when warm.
    If concerned you could / should check your coolant level. It should be approx an inch and a half from the neck of the filling cap when cold. If lower, add coolant and monitor over the coming days.
    Remember, don't panic, these cars are just cars and their engines are just engines.
  24. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    #49 F360_Spider, Mar 16, 2011
    hi guys
    just wanted to ask a question..
    so i bought this car like 2 weeks ago i wanted to know if i roughly paid the right price for it.. 4 owners its a 2001 spider in red with black leathers with red stitching. its a F1 but has 53k mileage (is this too high?, will it be hard to sell or is it just too high mileage now?) it also has these faults which i have been mentionting. it was up for 43k i paid 40k but got 750 back after reporting the faults so i paid a total of £39,250)
    does this sound ok? i dont want to live with it thinking i have bought a rubbish car or a car that has been wasted due to high mileage..
  25. greyboxer
    Dec 8, 2004
    12,637
    South East
    Jimmie
    Telling you you paid too much or too little is to some extent dependent on whether the faults turn out to be bad and also what the actual condition is which we don't really know yet
    Its too late now anyway so either answer isn't helpful - just get it right & enjoy it
