NEWBIE QUESTION ABOUT REAR BONNET | FerrariChat
Discussion in '308/328' started by steve meltzer, Sep 8, 2022.
  1. steve meltzer
    steve meltzer Formula 3
    Sep 18, 2004
    1,219
    with Enzo 8995
    I'M THE PROUD AND LUCKY NEW OWNER OF A '76 308 GTB. It looks like the rear bonnet on this car can be pretty easily removed vis-à-vis a telescoping strut system of sorts. I've enclosed a picture. Is this correct? Any pearls of wisdom? thanx steve
  2. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    741
    Omaha, NE area, US
    Steve
    Lucky indeed!
    It's not telescoping, but rather a quick release (both sides) that allows you to slide the engine cover off. I believe this was only used on the vetroresina cars.
  3. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    Thanx for your prompt and helpful response! yep, plastic. steve
  4. 4right
    4right F1 Rookie
    There are two wires that are attached to that mechanism that run along the inside of the deck lid exiting on both sides closer to the rear of the car. If you pull these wires, it will release the rear deck lid for removal.
  5. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    I don't recall seeing them, but let me look tomorrow. seeing no obvious wires on the bonnet, begs this question: how do the license plate lights get their power/ground?? (Vetroresina means you can't ground to body) thanx for the info. steve
  6. JC1720
    JC1720 Karting
    Jan 21, 2016
    139
    Welcome Steve!
    The lights are powered through the 2 cover latches - very elegant solution
    I have a similar car, will send photos that may help when I get back to the car
  7. 4right
    4right F1 Rookie
    Image Unavailable, Please Login You should have one of these on either side of your rear deck lid. If you pull these, it will release the deck lid. The wires are attached to the mechanism in your photo.
    Vetroresina means fibreglass/glass fibre/not metal.
  8. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    thanx so much. i found the "pull cables". steve
  9. JC1720
    JC1720 Karting
    Jan 21, 2016
    139
  10. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    thanx so much! steve
  11. dwhite
    dwhite F1 Rookie
    Steve, I know you're an OB/GYN, but are you already trying to deliver something out the back of that car. :)
    Car looks fantastic enjoy it.
  12. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    OK, Dave what's it gonna be....BBQ. or its antithesis....lox and bagels, with jalapenos? s
  13. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    If you remove the bonnet, have a person on each side…it’s not heavy but it’s large. When it’s off, lube the cable pulls and the latch mechanism on each “doggy dick” (no kidding, that’s what my GF called them) before they are reinserted into their sockets. Those little latch pins were really tight on mine after however many years so the pull required on the cables to release them was a bit unnerving.
  14. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    sounds like a good idea....does look anxiety provoking, really. arf, arf. steve
    Hannibal308 likes this.
  15. dwhite
    dwhite F1 Rookie
    Well that sounds like a nice breakfast and lunch. Now we need a place for dinner.
  16. daynyc
    daynyc Karting
    96
    What's with you Houstonians and jalapenos??? My Brit friend from Houston is obsessed by them and she pronounces the word with the emphasis on the first syllable.
  17. 4right
    4right F1 Rookie
    Great food in Houston, lots of TexMex and BBQ!!
