Newbie questions on my 2010 Cali | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Dixonator810, Jun 16, 2016.
  1. Dixonator810
    Dixonator810 Rookie
    Mar 20, 2016
    5
    KC
    #1 Dixonator810, Jun 16, 2016
    I just bought my first California and I'm getting acquainted with it. I have heard they have a battery tender port in the trunk but for some reason, I can't find it. Anyone able to assist on where to look? I have been all through out the trunk.
    Also, anyone know why I would have a switch and a dial under the driver side dash? See the attached pic. I found it looking for the tender port ;). I appreciate the support in advance.
  2. MDEL
    MDEL F1 Rookie
    4,042
    Southern Europe
    Mario
    #2 MDEL, Jun 17, 2016
    I have a Cali from the same year. Picture one there is the tender which is kept inside the red bag and normally stored in the trunk.
    Picture two is a view of the trunk and the arrow points to the little kind of flap door where is hidden the female plug where you connect the male plug of the tender. This little door as a lock which you open rotating using a coin or screw driver. On mine when I'm not driving the tender is always plugged and that way the battery is always fully charged and the probability of appearing electrical or electronic issues is much lower.
    Mine hasn't the switch shown in your picture so it doesn't look to be standard and better ask the seller what's it for.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    The switch and knob is likely the on/off switch and volume control for a K40 radar detector, which may or may not still be in the car.
  4. Dixonator810
    Dixonator810 Rookie
    Mar 20, 2016
    5
    KC
    Thank you Mdel
  5. Dixonator810
    Dixonator810 Rookie
    Mar 20, 2016
    5
    KC
    That's kind of what I thought but I haven't seen anything with regard to a display. Thank you!
  6. vjd3
    vjd3 F1 Rookie
    2,751
    Massachusetts
    Vic
    The K40 usually just has a pair of LEDs installed somewhere, if that's what it is. Might have a remote control. It's not a terribly well regarded system, or at least it was not in the past. Might be better now. Often installed at the dealership. I've ripped a few of those out by the roots in various Porsches over the years. See if there are any extra "lenses" in the front grill and back by the rear license plate, that would indicate it had laser jammers. The radar antennas are black boxes. Probably a speaker somewhere too. It probably beeps at you and the LEDs should flash on startup, if it's still intact.
    You can see some of the pieces visible on a California in the second post down ... this is a "hall of shame" site showing botched installs.
    https://www.gmpperformance.com/index.cfm?pg=carGallery&mode=displayVehicle&VID=3808#!prettyPhoto
  7. Dixonator810
    Dixonator810 Rookie
    Mar 20, 2016
    5
    KC
    Thanks VJD. I haven't found any sensors yet
