Newly rebuilt 308 QV engine- Does this sound right? | FerrariChat
Discussion in '308/328' started by yngwies308, Jul 10, 2011.
  1. yngwies308
    yngwies308 Rookie
    May 30, 2007
    9
    Tulsa, OK
    Brian
    This engine was recently rebuilt and was started up for the first time about 3 weeks ago. It now has about 8 miles on it. Everything is stock except for the high-compression(10.5:1) JE pistons and the exhaust headers.
    Here is a video I shot this morning:
    [ame]http://www.youtube.com/watch?v=XnKr6CF6w7Y[/ame]
    I'm concerned about the clickity-clack noise from the top of the engine. Do you guys think this sounds normal? If not, what do you think is the problem?
    Thanks!
  2. thecarreaper
    thecarreaper F1 World Champ Silver Subscribed
    Sep 30, 2003
    18,067
    Savannah
    Sounds bad to me. Also sounds like its in the top end.
    Make sure it does not have a exhaust leak before you pull the engine back out again, as thats the only easy fix that i can think of. ( if its not inside the top of the engine)
    I would NOT run it anymore.
    Have you rotated it by hand to narrow down the noise?
  3. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    Doesn't sound right at all. I wouldn't run it again but take it to the shop that rebuilt the motor and have them figure it out. If that's not an option check for exhaust leaks, that the check vavle below the oil filter has the right air flow direction (arrow pointing to the drivers side), check the wires for crosstalk and correct firng order and also check the exhaust for obstruction like a mouse nest. Check to make sure you have oil pressure too.
  4. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    when i started my motor after my winter service it sounded 10 times worse then yours....it was an exhaust blockage.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    How in the heck did it leave the shop sounding like that? If they are not out of business now, they should be.
    Although it's hard to tell from the sound on the computer, it has a clackety valve-related sound to me and might be really loose valve clearances though it could be multiple header leaks at the ports. Header leaks usually have more of a "snap" sound than the clack sound but again, audio on a camera video and played through computer speakers is not very accurate soundwise so it's hard to tell.
    You said they put in high compression pistons - did they clearance check the valves to the pistons or just install pistons that were "supposed to work" and left it at that? I know from experience that it is possible to have an engine running where the valves are just kissing the piston tops and you will get that sort of clatter but once the engine gets hot and gets some serious throttle, it will come apart.
  6. Brian Harper
    Brian Harper F1 Rookie Owner Silver Subscribed
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I know it can take a second to get the light to go off and the gauge to come up, but in the second that the video shows the gauge and light, the light stays on and the gauge doesn't move. That changes when the engine is running, right?
    It also seems odd when cranking. It cranks pretty quickly and then bogs down and then starts. Seems like a clue. Clogged oil cooler? When the cooler pressureizes the oil pump drag slows the starter? Purely a guess.
  7. tempest411
    tempest411 Formula Junior
    Dec 3, 2010
    564
    Wow, I went back and took note of that as well. That does sound very troubling, doesn't it? Did the engine sound like that from the beginning? I'll be watching this thread to see what happens...
  8. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Yikes!!! It does sound like it is coming from the valvetrain. But, it does seem odd that the cranking does suddenly slow down...could be exhaust blockage like OP had mentioned...it takes a second or two for the pressure to build up in the exhaust.
    Good luck.
  9. Ferraripilot
    Ferraripilot F1 World Champ Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    Valve train clearances or incorrect piston to wall clearance sounds like the issue. Also, with 10.5:1 compression you want to back off on total ignition timing which unfortunately is sort of tricky with a QV. The problem is with that compression the combustion efficiency is such that it can no longer handle (without the possibility of detonation) the stock ignition timing. Be careful but if it were me I would back out a couple degrees at max advance.
  10. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    I hope that engine has oil in it!! Have you measured on the dipstick?
  11. yngwies308
    yngwies308 Rookie
    May 30, 2007
    9
    Tulsa, OK
    Brian
    Yes, the engine has oil and oil pressure. IIRC, the pressure was 1 tick below the 85 on the gauge. These are all good suggestions. My friend who built the motor is currently out of town, but when he gets back we'll do some troubleshooting.
    Thanks for all the replies and keep them coming if you think of more stuff.
  12. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Ask you friend if his tools are all accounted for :D
  13. tempest411
    Dec 3, 2010
    564
    If you've confirmed you have oil pressure, go for the obvious and simple to check. Make sure all of the nuts & bolts in the exhaust system are tight. An exhaust leak or two will make any engine sound horrible-and can often be confused for more serious problems.
  14. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    On a lighter note, I really like the tan dash.
  15. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    536
    Elgin, IL
    Dave
    Report back with your updated fuel mileage in your new diesel 308.
  16. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    Any news?
  17. Ferraripilot
    May 10, 2006
    17,849
    Atlanta
    John!
    I think I can speak for the poster here as I have some news on this.
    I spoke with the poster a week or so ago and we went over clearances. The clearances were checked within the past couple days and it was found that a few were not where they were supposed to be with one being very out of whack (.025 clearance!).
  18. yngwies308
    yngwies308 Rookie
    May 30, 2007
    9
    Tulsa, OK
    Brian
    Yep, my mechanic and I checked the valve clearances last night. For the most part the valves are slightly loose. The spec says intake should be .20mm-.25mm and exhaust should be .30mm-.35mm.
    My intake valves mostly range from .25 - .30 mm exept one was .20mm- .25mm, one was right at .30mm, and one was about .32mm.
    My exhaust valves mostly range from .35mm-.40mm. Three were a bit tight: one was .28-.29mm, one was .30, and the other was .31mm. One was very loose: it measured .66mm.
    So probably that loose one was making most of the noise. I'm going to bring the clearances back into spec and let you know if that helps the engine sound.
  19. thecarreaper
    Sep 30, 2003
    18,067
    Savannah
    good luck . i would at least pull off the oil filter and cut it open for inspection / metal, as well as consider changing the oil again.
  20. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    If the valves were set when the engine was assembled I would do a leak down NOW! Lost
  21. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    If the valves clearances are that far off, I'd wonder what other tolerances might have been missed when the engine was put together. Just sayin'.
  22. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Worst sounding engine I have ever heard. I'd be removing it and starting again ... or atleast removing all cam covers and sump and checking things.
    Pete
  23. italianjoe
    italianjoe Formula Junior
    Jun 30, 2010
    295
    dearborn heights mi
    joe
    idn guys if sounded funny when it was being cranked over ....... it did not sound right when the starter was being engauged ........just from what i can hear maybe a starter and flywheel issue........but in order to be sure i would use a stethoscope to see where the noise is coming from.........just my thoughts
  24. f1nxlife
    f1nxlife Formula Junior BANNED
    May 11, 2010
    258
    harbor city ., calif
    brett falcigno
    that doesnt sound ., at all ., right,,,hope you sort it out,,,
  25. GrayTA
    GrayTA F1 World Champ Owner Rossa Subscribed
    Jun 25, 2006
    15,130
    Deep South
    PDG
    FerrariPilot and I talked about this a few days ago, but I was just able to get on here to see this thread!!
    Yikes!! Thats a bit scary!!!
    Please do keep us up to date and let us know what happens with it all!!!
    PDG
