Next Ferrari Super Car and KERS | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Napolis, Apr 19, 2012.
  1. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The new Enzo will have KERS as will the Porsche 918 and the New McLaren Supercar.
    P 4/5 CM has KERS and we just finished an interesting test.
    Basically KERS really works and can add to both VMAX and acceleration. You can recharge it by braking (converting Kinetic energy to stored electrical energy) and by using the gas engine to charge the system when maximum power isn't needed for example when stuck in traffic or cruising down the highway. In our race we'll charge both ways as in addition to braking there are also times when you're stuck in traffic and can't use maximum power.
    The interesting issues include how to activate the extra power and engage engine charging. In our car the driver will control both but on the street I suspect computers will control this a bit and have different levels accessed by a switch of some kind.
    Maintaining and controlling KERS system and batteries temperature is also an interesting challenge but it can be done. As for out put we can make a controllable amount of HP but of course the more we make the shorter time we can use it. Once we start racing again we'll learn what percentage of a lap we can use it vs recharge time. The system to enable a driver to know available charge is also complex.
    Brave new world and I look forward to seeing how Ferrari proceeds with it's new Supercar.
  2. Tenney
    Tenney F1 Rookie
    Feb 21, 2001
    4,286
    Can a gauge be created to accommodate?
  3. elipinski
    elipinski Formula 3
    May 14, 2006
    1,390
    Emanuel
    Very interesting, thank you for the insight. Regards-e
  4. werewolf
    werewolf F1 World Champ
    11,022
    goodbye
    I'm really interested to see what Ferrari comes up with as well.
    Remember that you're storing energy, not power. Power is energy/time ... if you drain that stored energy quickly, you'll get higher power ... but for a shorter period of time.
    The interesting design parameter (among many others, of course) is : how much energy will you store? Every extra bit of extra energy storage adds the potential for more power, but also adds weight ... so there's an optimization here. The optimum is not, most likely, zero energy stored with zero weight ... but neither is the optimum to be found with massive amounts of energy & weight.
    Can't wait to see what Maranello comes up with :)
  5. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    It's tricky as the rate of charge and discharge isn't linear and you need computer feed back to interpolate the state of charge. We're experimenting with a combination shift light string of LED's (red) and a state of charge string of LED's (white) but it's not easy. We'll learn more tomorrow and at our race next Saturday.
    KERS push to pass boost is real. I can't give out specific data at this point but it's a good shot. How much you feel it is a question. On our VMAX test our Driver wasn't sure that it worked but our telemetry showed that it really had.
    Ferrari numbers (rumor) are 120 KERS hp vs 800 gas hp. which is a similar, slightly greater percentage increase as to what we're seeing but keep in mind we're hoping to use it a lot more than the average super car driver will and we need to run it at less hp on a percentage basis in order to keep it usefully charged during a lap.
  6. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Weight isn't an issue for us as we still have to add ballast to reach minimum weight (About 2850 lbs.)
    Our system weighs about 200 lbs all in.
  7. werewolf
    11,022
    goodbye
    i get that :)
    My comment is more directed at a street car, let's say, with no sanctioning-imposed weight limit. Sometimes, we hear a comment like : "KERS is a waste, because it adds weight." To which i'd respond : "Really? Wouldn't you add ten pounds if it gave you a hundred horsepower?" :)
    Yes, we all know that KERS weighs more than 10 pounds. My point is that you can't just look at the weight alone, and conclude that KERS is a waste ... that same thinking would lead you to decline the 100hp for 10lb offer ;)
    It will be interesting to see how Ferrari optimizes this energy/weight problem. My guess is that they'll be looking to store just enough energy (balanced against the weight penalty) to post some blistering laptimes on a few of the more popular tracks ... even though it's a street car, i think they'll be looking for laptime metrics more so than top-speed (or even zero->sixty), for example.
  8. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #8 Napolis, Apr 19, 2012
    Lap time system would also depend on the length of the lap. In broad numbers we're hoping for a 15 second improvement over an 8:30 non KERS lap at the Ring full course which is 1:30 longer than the shorter course most quote times of . Lap after lap for 24 Hours for 200 lbs. (non penalty)
    I agree on Ferrari being less interested in KERS for 0-60 which is traction limited. They'll already get to sub 3 seconds their with 800 gas HP. In push to pass it will help.
  9. zxcv
    zxcv Karting
    Aug 1, 2011
    89
    Have you seen car body of Enzo successor? One guy from Italy who is famous car spotter claims that he already saw it at Ferrari factory.
  10. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Nope.
  11. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    The tradeoff depends on the power/weight ratio of the car (usually), so if you're improving the ratio significantly, it's probably worth adding the weight. In the case of Jim's car, at 2850lbs with 500hp? - you'd need to be adding at least 1hp for every 5.5lbs (and probably more like 1hp for 4lbs), otherwise you will trade off reduced acceleration for more top end speed while also reducing handling prowess. In your example, if you could add 3hp for that 10lb weight gain, it'd probably be worth it, let alone 100hp.
  12. JWeiss
    JWeiss F1 World Champ
    Nov 18, 2010
    12,181
    NYC and Long Island, NY
    JWeiss
    So, we can envision a manettino for KERS. One setting probably full Auto - uses their default map for charging and discharges as much as possible during WOT. Other settings give PtP functionality on the discharge side, with perhaps a few different maps on charging (including brake charge only). Also, possibly a setting or two for Auto-discharge, but with more conservative maps than the full-dump-at-WOT mode. I have trouble envisioning a Push-to-Charge level of control.
    As for me, I like to save one boost for the run to the finish line, and use the other two whenever the gal in the passenger seat yells "Hit it!". Maybe they can have a setting for that.
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I think you're right about a manettino. One issue is that for CAFE they may have a pure electric mode. The good thing about KERS is torque. It's instant and you need it for VMAX especially in a high downforce car like ours.
  14. Mr. Francesco
    Mr. Francesco F1 Rookie
    Oct 10, 2010
    4,934
    Mr. Francesco
    I'm still curious to if actually using KERS will be an automatic (controlled by the ECU) or manual (controlled by the driver) process on a streetcar.
  15. werewolf
    11,022
    goodbye
    A few interesting properties of DC electric motors may help illustrate how nicely they complement an internal combustion engine.
    A DC electric motor has two input quantities of interest : voltage, and current.
    A DC electric motor has two output quantities of interest : speed, and torque.
    To first order, assuming no parasitic losses (not a bad assumption, electric motors tend to be pretty efficient), it so happens that : output speed is proportional to input voltage, and output torque is proportional to input current.
    Finally, there's a classic torque vs speed relationship that's quite accurate for almost all DC electric motors : a straight-line relationship, with negative slope :
    T = Ts - (Ts/wn)*w
    T = Torque, w = speed (angular)
    Ts = stall torque, wn = no-load speed
    Power Calculations:
    You can calculate the input power by multiplying voltage*current, or the output power by multiplying speed*torque. Either way, you'll find a classic "parabola" in the power vs voltage (on the input side) or power vs speed (on the output side) relationship, with a maximum power value at 0.5*wn.
    Conclusions:
    DC electric motors tend to generate maximum torque at zero speed, and they tend to generate maximum power at one-half their usable speed. In contrast, internal combustion engines tend to generate maximum torque somewhere near half of their usable speed (although the curve tends to be broad and flat-ish), and maximum power near their full usable speed. That's why this "pairing" of technologies tend to complement each other rather nicely.
  16. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    My head hurts. Jeff I would be happy to discuss this topic with you over a glass of red wine & dinner at one of our favorite restaurants in Laguna Beach. Trouble is, I'm not sure I would have ANY meaningful input, besides complimenting the chef :)
  17. werewolf
    11,022
    goodbye
    if you're buyn' ... i'm there :)
  18. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    I am, anytime, well overdue!
  19. werewolf
    11,022
    goodbye
    didn't mean to derail, rather just elaborate on the torque benefit of electric motor assist.
    DC motor gives max torque at zero rpm, and max power at half its usable speed. In a sense, the torque & power benefits of an electric motor are "shifted" down the rpm range, compared to their internal combustion counterparts. One reason why the combo tends to work well.
  20. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The interesting thing we learned is that because of this full torque at zero rpm you really want to let the gas motor get the wheels rolling before you add KERS as it puts a huge strain on the system to start up from a dead stop as our motor/generator is directly coupled to the gearbox main shaft. We actually re engineered a new main shaft that tapers and acts like a torsion bar to smooth this transition. As our gear box has no syncro's our shifts are very hard and we wanted this shaft to withstand the forces for 24 hours of racing. Hewland was very helpful in working with us to make this possible.
  21. werewolf
    11,022
    goodbye
    now that's interesting!
    We tend to immediately think of zero-rpm max-torque from an electric motor as nothing but goodness ... hadn't even thought of the stress to the rotating assemblies, "punching" them with max torque from a standstill.
    maybe ya wanna delete this stuff to keep it from the competition!!
  22. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    No KERS powered vehicle has ever finished the 24 Hours of Nurburgring and this year we're the only one trying so I guess it's ok. :)
    I'm really not surprised that Porsche is doing a lot of development with their KERS (several years) before they start to sell it. Using it in a high performance car is a bit tricky. It will be interesting to see how Audi and Toyota do at Le Mans with theirs.
  23. arakisfilip
    arakisfilip Formula Junior
    Jan 25, 2004
    295
    I have a suggestion, maybe it would be a good idea to make an added automatic control for low consumption. in this mode a processor will charge discharge to help fuel consumption instead of performance. For safty car periods, or when you just need to go an extra lap....
  24. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    At the Ring there are no full course yellows so safety car's aren't an issue. A lap is over 16 miles and with the onboard fuel allowed we're already going for the maximum number of laps between stops. We have thought about trying to conserve fuel to go one more lap between stints but it's edgy. In our last 24 we came in once with only 1/2 of a liter of fuel left. We will experiment with that and see.
  25. Tenney
    Tenney F1 Rookie
    Feb 21, 2001
    4,286
    The future of rock 'n roll - show 'em who's boss next Saturday.
