Nitrogen in tires | Page 2 | FerrariChat
Nitrogen in tires
Discussion in 'Technical Q&A' started by Bill Sawyer, Feb 26, 2004.
  1. Diablo
    Diablo Formula Junior
    Nitrogen is used at the track for the FOC/FCA events here in the north east depending on the company you run with.
    It helps due to the expansion of oxygen in regular air in tires.
    If you guys run you car on the track, take temp and pressure readings when HOT. You will see the difference.
  2. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    Just to be clear, oxygen doesn't expand significantly differently from nitrogen. Both gases will expand predictably with heat.
    It is moisture in air (humidity) that you want to avoid... water expands tremendously with heat as it changes from liquid to gas. Thus, with a little more humidity in your tires, you'll find that your tire pressures increase much more than expected from cold to hot; and more importantly, if the moisture is different in different tires, then your handling balance will be disturbed as the tires heat up.
    So, for your track events, dry air is every bit as good as pure nitrogen.
  3. Bill Sawyer
    Bill Sawyer Formula 3
    Feb 26, 2002
    2,108
    Georgia
    Okay, we've established that it's a good idea for the track...what about the street? Does anyone use nitrogen in their street cars? Are there any discernable advantages?
  4. Brian C. Stradale
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    If you have a real low mileage Ferrari... to where your tires, tread-wise, last for years and years... then keeping the oxygen out of them will greatly reduce the oxidation of the rubber. In that case, it is arguably an advantage.
    If you're going to go through your tires in less than 3 years anyway, then pure nitrogen is probably not of significant value on the street. (That 3 year number is fairly arbitrary.)
  5. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    So, collector cars should be using Nitro in tires?
  6. WCH
    WCH F1 Veteran
    5,186
    Granting the benefits of nitrogen, IMHO the great majority of track day drivers and amateur racers should concentrate on driving and set-up long before even thinking about nitrogen. My advice is that notrogen is NOT worth it for most track applications, and I'm reminded of folks in SCCA I've seen using tire warmers. It looks cool, though, and if it adds to the fun, what the heck, it can't hurt.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Okay so were is the best place to get the tires filled? Can you go to a truck stop that services big riggs, or were?
  8. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    Tires must be drawn down to ZERO psia(bsolute) with a vacuum pump, not just have the core pulled out and left at atmospheric, even repeatedly won't help.
    As I've said before, "suck, then blow" (suck the air out, then blow the nitrogen in).
    And on the subject of mounting lubricant and race tires, mark the position of the wheel's valve stem at mounting time, then take a look after a track session. Hmmmm. I've seen top notch tire/ wheel combinations spin as much as 180 deg in 30 minutes. Typically at least a couple degrees, usually the fronts due to braking. Trans Am cars spin the rears occasionally.
    Best regards,
    Rob Schermerhorn
