Nitrogen | FerrariChat
Nitrogen
Discussion in 'Tracking & Driver Education' started by ktr6, Mar 31, 2012.
  1. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    Just got a new set of Toyo RA1s for my spec miata and they came filled with nitrogen which I have never used before. Do I need to do anything different? Is it ok to simply adjust pressures with air like I normally do? Do I still start at the cold pressures I have normally run?
  2. Europeanroadandracing
    Europeanroadandracing South Carolina Professional Ferrari Technician
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    I wouldn't expect any great difference on the street. On the track however you will. Nitrogen is pure where regular air is a mixture of other gases and moisture. Those will cause a pressure change as the tire temps increase which will affect the handling characteristics. Nitrogen will change very little in comparison and therefore makes for smaller setup changes.
    Karl
  3. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    If you want to maintain the pressure stability that Nitrogen offers, you need to keep filling it with Nitrogen. If you start adding air to increase pressure, then you'll be back to the larger variances in pressure changes as the temps change.
  4. b-mak
    b-mak F1 Veteran
    Jan 23, 2004
    6,846
    Star Alliance Lounge
    I've used the air you breathe to set numerous track records and win numerous races.
    I can't be bothered to waste my money on that nonsense, until I'm competing at a higher pro level.
  5. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    The air we breathe is about 80% nitrogen to begin with.
    Nitrogen, like every other gas, will expand and contract according to temperature variations.
  6. Europeanroadandracing
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    I agree 100%. I've done the same.
    On another note, the OP hasn't even taken the time to respond although several of us have taken the time to respond to his question. Let's remember that.
  7. b-mak
    b-mak F1 Veteran
    Jan 23, 2004
    6,846
    Indeed, Karl. I suspect a consistent Spec Miata podium finisher wouldn't be asking that question.
  8. ProCoach
    ProCoach F1 Veteran Owner
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    True dat...
  9. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    Thank you everyone for the replies, appreciate the advice. Sunday went well at Road Atlanta with no major issues, simply ran an old set of Toyos with air for the weekend until I could gather more info for my first new set-was surprised when they arrived with green caps on the valves.
    As for not responding-give a guy a chance-this is the first opportunity I have had to sit and reply and its 01:00 hours on Wednesday morning.
    No I am not a consistant spec miata podium finisher at this time, Sunday was the fifth day in my new to me spec miata. Enjoying learning the car, managed a 1:47 on old tires. Still have a long way to go. Will be sticking with air. Appreciate the warm welcome.
  10. ProCoach
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Congrats, that's a good time. It's ok, this crew can be as rough as your typical NASA or SCCA SM crowd! :D
  11. Rob in Potomac
    Rob in Potomac Formula Junior
    Mar 3, 2006
    454
    Potomac, MD
    Robert
    I often used nitrogen in my RA -1 and RA - 888 on my 360 spyder and only normal air in my GT3 and honestly, cannot tell the difference. The cold and hot pressures stay constant during the day, so I am not certain what the actual advantage is.
    Rob
  12. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    The difference is in the moist.
    Nitrogen comes from a bottle and conntains no moist at all.
    Air from a normal air " fill" station will contain some or more moist.
    it is in fact the moist that affects your will influence the pressurechanges the most.
    If you would fill your tires with "medical" air you would have the same performanvce as with nitrogen
  13. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    use a well maintained compressor... compression process will precipitate any water to the bottom of the storage tank... ever notice the drain at the bottom of compressor's air tank, check it frequently... also filters can be installed inline which will strip moisture and other contaminants before the air is used
  14. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    28,988
    socal
    Just about every tire when mounted is bead seated with shop air. So unless you got anhydrous shop air or AH nitrogen whatever you use to service your tires later will be a waste of time. Trackside then nitrogen becomes a convenience to air up tires, run your air tools and run your airjacks.
  15. Kyoso_Joey
    Kyoso_Joey Formula Junior
    Nov 7, 2010
    275
    Scottsdale
    Joey
    Nitrogen is over rated. Use helium...or lead.
  16. Shane86
    Shane86 Karting
    Dec 2, 2011
    172
    North Carolina
    Shane
    We have been filling airplane tires with Nitrogen for years......reason.....stability during high temps. These big *****es produce glowing brakes X 4 on a wide body bogie.......and stays hot for some time.
    I raced SM for a few years too but not sure what our owner ran in his set ups but he was first class so likely was Nitorgen. Congrats at the lap at Atlanta....SM is a great machine.
