So, it appears there is no "accessory switch" (typically number 2 position on the ignition switch on most cars) on a 360.... If I decide to listen to my stereo while I'm parked (I have an aftermarket set up with power amps, upgraded head unit and subwoofers) does anyone know how long I can listen tomusic before the battery doesnt have enough juice to restart the car? On my BMW M6, I did a test, if I use position 3/III or ignition switch while listening to my stereo (instead of position 2 accessory mode) since all the electronics are turned on - battery is dead in about 2 - 3 hours. Does anyone know for a 360? Thanks in advance. Dan
Dan, you are the pioneer here (pun intended?). I know you have a big system so use caution as you don't want to kill your battery. I have been meaning to pick up one of these for while. Maybe you could try one out. I know you like tools too! Plug and Play Cigarette Lighter Port Tester Image Unavailable, Please Login
Cool! Thanks Kevin! I was ready to buy one until I just remembered previous owner removed the cig lighter and replaced it with Carbonio CF cup holder. My plan is to install a USB jack using the same power wires somewhere in the center console instead to charge my cell phones. Just havent had time yet as I spend so much of my time now just enjoying driving the car. Amazon.com: Blue Sea Systems Dual USB Charger Socket: Sports & Outdoors Dan
Dan- The battery will last about the same as if you had an accessory position. You can have someone hotwire the radio for you, but then you have to remember to turn it off after every drive. Many of the cars from the 50s and 60s were set up that way.
