No Buttons, red or otherwise, on ECUs | FerrariChat
Discussion in '348/355' started by mseals, Sep 15, 2007.
  1. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    I have a 1992 348ts and tried to check the ECU codes today, but, alas, no buttons. Thanks to the 348 Primer, I know I need to order the Tester Cable (PN 146196) and the button (PN 145810), but have a few questions.
    1 - Do I order two of each and permanently install them? If so,where are they installed?
    2 - Where do I plug the Tester Cable into the ECU?
    As always, I appreciate any assistance.
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #2 No Doubt, Sep 15, 2007
    The parts that you ordered are shown in this diagram as #2 and #3. They just snap on. You can unsnap them and move them from one ECU to the other, or you can buy two of each and snap them into both ECUs. The ECUs are located behind the carpeted panel that is behind both seats in the driver's cockpit.
    PS: you will also need to install two light bulbs behind each of your ChecK Engine Lights (CEL 1-4 and CEL 5-8). Easy to do. Just unscrew the two phillips screws that are at the bottom on the extreme left and right flanks of your black driver instrument pod.
    You don't even have to buy new bulbs. You can move your seat belt warning light bulbs into the CEL slots if desired.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #3 No Doubt, Sep 15, 2007
    Checking your codes will *always* be possible on Motronic 2.7, but may not always be possible on Motronic 2.5. Early 348's had Motronic 2.5. Later 348's have M2.7.
    Easy to pop your engine lid to look for two Throttle Position Sensors (TPS), though.
    If you have two black TPS's, then you have M2.7.
    TPS are #7 in the diagram below. They are black and placed on top of one or both throttle bodies.
    If you only have one TPS, then you have an early M2.5 348.
  4. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    This has to be the best and cheapest upgrade on the euro 348s possible. and so easy! It even works a treat telling me i am fine. you dont even have to buy a push button of course, just make up a switch to wire up to the two connections - there are 3 wires there will have a look and see which two i mean.
    Many thanks for the info.
  5. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Walclare, I can't find the 'official' wire (listed for $22) available anywhere. If you can help please do. I appreciate it.
    Thanks,
  6. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
  7. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Thanks Andrew.... I really appreciate your assistance....needless to say, I have a new site bookmarked thanks to you.
    Mike in Kuwait
  8. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Philip Barnard-Brown
    Hi Walclare. I have been unable to buy the wire from Europarts. Got the push button alright,but no good without cable. Out of stock.The button only requires two wires as you mentioned above.The connection to the ecu has 3 wires.I was wondering which two wires are used? I can probably make up my own connections.CAN ANYBODY HELP?Thanks in advance. Regards Phil.
  9. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    My car is away for some tweaking at moment ready for the season start.
    As soon as i get it back Ill check out which wires, very easy to make up a lead, and get back to you.
  10. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #10 No Doubt, Feb 8, 2008
  11. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    what he said
  12. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    I keep tellin' you...
    Daniel is the best...!
    Mike in Kuwait
  13. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Hey guys thanks for all the help.This weekend is now looking promising.Cheers!
  14. fatbillybob
    Aug 10, 2002
    29,253
    socal
    I have the official buttons if some one needs them. But why spend the money or the time? Just bend a paperclip and you can short the terminals of the 2 wire pigtail on your wiring harness by the ecu's.
  15. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    Your right FBB but remember Prince Phillip and us other euros don't have the pigtail in our 348s. That was the part he was short of in the first place. Not that that isnt easy enough to wire up, as long as you know which 2 of the 3 to wire. back to no doubts post.
    Nice to see royalty posting here by the way. Hes obviously turning to cars now shooting season has finished.
