"No Cal" warning light on tach? | FerrariChat
Discussion in '360/430' started by cyclisto, Nov 7, 2009.
  1. cyclisto
    cyclisto Formula Junior
    Nov 21, 2008
    357
    Utopia
    Sy Kleesteau
    Even thought the RF tire pressure is adequate, I was getting the low pressure warning light with "38 PSI" and "37 PSI" blinking. Then, suddenly, it started blinking "No Cal." What does this mean?
    In two weeks, I'm taking it in to the dealer to replace the manifolds, but if this is serious, I'd like to take it in earlier.
    Thx for your help.
  2. technician F
    technician F Karting
    Sep 15, 2009
    57
    You can press the TPMS Cal button when key on .Then drive your car about 15min.to calibrate the TPMS.If "no cal"still on at dashboard,maybe problem in TPMS.
  3. Tarek K.
    Tarek K. F1 World Champ
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    It seems to be the season for TPMS failure. I have the same problem. Pressed the calibration button and it went into calibration mode, but as soon as the calibration cycle ended it showed No Cal again.
  4. technician F
    Sep 15, 2009
    57
    I think your car is F430.Some problem in the TPMS in F430.Can not calibrate easily.You must go to the dealer to fix it.
  5. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    Thanks, I'll take it to the dealer soon.
  6. 430planb
    430planb Rookie
    Jun 1, 2007
    28
    Bangkok, Thailand
    Lojanagosin
    change the sensor. i had his problem many times and cannot fix it. i changed the sensor twice now it is fine. best if u add little more presuure than instructed.
  7. cyclisto
    Nov 21, 2008
    357
    Utopia
    Sy Kleesteau
    thx all. is this a warranty issue? if not, how much should i expect to be gouged for it? ;-)
  8. tazandjan
    39,043
    #8 tazandjan, Nov 8, 2009
    Sy- TPMS problems typically pop up at the onset of colder weather when tire pressures drop enough to cause a low tire pressure or a No Cal warning. If your car was built before ~September 2007, you have a separate tire pressure calibration button (see page 125 or so of your OM). Carefully set your tire pressures while cold. To calibrate the TPMS, turn on the ignition, but do not start the engine. Depress the calibrate button for approximately 5 seconds until a CAL warning illuminates and release the button. Start and drive the car for 10-20 minutes and the system will calibrate itself. If this does not work, the system should still be under warranty.
    Taz
    Terry Phillips
  9. cyclisto
    Nov 21, 2008
    357
    Utopia
    Sy Kleesteau
    thx taz and others. :)
  10. 458italias
    458italias Karting
    Sep 15, 2012
    148
    Cleveland Ohio
    found it - thanks
