No Cats, More power? | FerrariChat
Discussion in '360/430' started by MufflerMan, Jul 28, 2006.
  1. MufflerMan
    MufflerMan Formula 3
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    I am thinking about removing my cats to see if there are any gains (for the track only of course), but I can't seem to find any videos of this being done on a 360 with a Tubi. I was wondering if anyone here knows where to find something like that. Also, if anyone has done it, what are you doing about the CEL? On my Lotus I used extensions for the O2 sensor's that took the downstream O2's more out of the exhaust stream, it worked great, however I am not sure if it will work on a 360. Any info is appreciated!
  2. Harmonyautosport
    Harmonyautosport Formula Junior
    Apr 28, 2006
    683
    New York
    No cats is the best way to go as far as power goes. The CEL light will no ttrigger any limp mode either. On all cars that we have sold test pipes to report a CEL. The only video I have is a car with Harmony headers, Test pipes, and TUBI NGT exhaust. Not sure which exhaust you have.
    http://www.harmonyautosport.com/headersdyno.wmv
  3. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    why not just use the hyper flow cats? They are supposed to flow nearly as well as a straight pipe. In CA it's not worth the hassle with smog, etc for the little extra you gain on straight pipes, vs. hyper flow cats.
    Here is my recent post on the subject:
    http://www.ferrarichat.com/forum/showthread.php?t=114655
    Ray
  4. MufflerMan
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    Ray, I have the ability to fabricate my own test pipes so it's not cost effective to buy the hyperflows for me. BTW Hyperflows are not Ca OBDII approved anyway, so they are just as illegal as test pipes according to the BAR and the CARB. As I said this is for the track anyway and as effecient as the Hyperflows are, they are definitley not as efficient as a pair of pipes not to mention a lot less underhood temp.
    Harmony, impressive rear wheel gain from your headers, however that appears to be two different cars in the video, did it get painted inbetween the dyno runs? Do you have a dyno test results from cats to test pipes with no other changes. BTW I have a standard Tubi.
  5. Ricambi America
    Sponsor Owner
    That is not correct. Feel free to contact me or Troy @ HyperFlow for the specifics of his certification.
  6. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    Same car, psychotic owner :D
  7. 996TTnoprob
    996TTnoprob Karting
    May 14, 2006
    61
    midwest
    Do you sell the Hyperflows for 360's? Thinking of ditching the cats also.
  8. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    That's incorrect. The hyper flow cats are 50 state smog legal.
  9. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    Anyone know mufflers to suit that will give proven power gains?
  10. Harmonyautosport
    Apr 28, 2006
    683
    New York
    Same crazy owner just painted it.
  11. Ricambi America
    Sponsor Owner
  12. Harmonyautosport
    Apr 28, 2006
    683
    New York
    We carry straight pipes and high flow cats. Contact us at [email protected] for more information. Both in stock.
  13. ted 191
    ted 191 Karting
    Sep 6, 2005
    225
    yorkshire
    chris heeley
    I run a tubi with test pipes,awsome sound,after about 40 miles the engine light comes on and stays on, but performance not affected
  14. sketchsk85
    sketchsk85 Formula Junior
    Aug 1, 2005
    577
    Denver
    Thomas
    that flat black paint looks gorgeous in the 2nd part!
    -Thomas
  15. Harmonyautosport
    Apr 28, 2006
    683
    New York
    its blkblkblk car.
  16. MufflerMan
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    Apparentley my source about Hyperflows not being Ca legal was wrong. I stand corrected, I didn't know Hyperflow had Exective order and CARB approval. You have to give it up to the knowledge that is available on this forum. Thanks for the information guys!
  17. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    The hyper flow cats are very nice :) In my opinion, they are the best out there for the Ferrari.
    Ray
  18. MufflerMan
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    Does anyone know if the Larinis are CARB legal?
  19. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    I have straight pipes (no cats) and a Tubi NGT on my CS. It sounds amazing.
    For the CEL issue (it freaked me out a bit at first), you get used to it. However, to be sure the CEL is related to emissions each time it illuminates, I purchased a scan tool that plugs into the OBDII port under the dash to read the CEL error codes and reset them. It then takes about 40-60 miles of driving before the CEL comes back on.
    The sound is definitely worth the CEL bs.
  20. MufflerMan
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    There are ways to trick the OBDII into thinking the cats are still there, the first being a low tech spacer that lifts the rear o2 out of the exhaust stream a bit. The second being a little higher tech, it's an electronic simulator that simulates the resitace sent to the computer to tell it the cats are working. The problem is, I haven't heard of anyone doing this on an F-car. I dont know what sim will work, and I am not sure that the spacer will work (it did on my 98 Lotus). I guess I will find out and let you guys know.
  21. Ricambi America
    Sponsor Owner
    I know of a few folks that move the O2 sensor out of the stream, and they claim it works well. Cheap 'n' easy.
    I still wonder how you pass an emissions test without cats... (apart from a $100 bill to the operator). Then again, when I had pipes on my 348 (I now have HyperFlows), the car actually blew clean numbers if it was nice and hot. Might have been a fluke, might have been a whacked out gas reader too.
  22. yellow 355
    yellow 355 Formula Junior
    Mar 25, 2005
    503
    ocean city,nj
    Ben Murphy
    I did a clip with ANSA and pipes....I have some ricers that did the video and hooked up the o2 sims NO CEL.....They also installed the exhaust system. They are employees and very good at the cat removal deal with there ricers...BEN PS...THEY ARE DOING MY EXIGE NEXT...
  23. ^@#&
    ^@#& F1 World Champ
    12,091
    you aren't gonna sell the exige??
  24. yellow 355
    Mar 25, 2005
    503
    ocean city,nj
    Ben Murphy
    No not selling it yet... I will do as always drop a bunch of $$$on upgrades to please the next owner....
  25. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    I heard about placing a spacer in between. I haven't had much time to spend identifying what works. If you find out, please let me know!!!
