No communication on RH engine ECU on 360. | FerrariChat
Discussion in 'Technical Q&A' started by prospeked, Mar 8, 2007.
  1. prospeked
    prospeked Rookie
    May 12, 2006
    11
    Australia
    Joe
    HI all,
    Im doing some work in a work shop at the moment and i have a 360 with the 7.3 motronic system in it. The problem i have is i cant communicate with the right engine ecu. There is nothing wrong with the ecu as i have tried it in another 360 and also tried swapping sides with the left ecu and all is on with the control unit.
    I cant find any faults around the right hand fuse box with the motronic fuses. As far as i can tell there are no wiring issued but it has been had to determine 100% as i i dont have wiring diagrams but i am fairly confident the wiring is ok.
    Anyone have any ideas? I am using a Ferrari SD2 with the correct software so its not the testers fault.
    Thanks!
  2. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Check your wiring connectors inside the passenger compartment behind the seats as well as towards front center console. The female pin sockets have a spring blade that breaks off easily. So it may appear everything is ok but the male pin is not making proper contact in the female pin socket.
    You really need a full wiring diagram to find the right plugs to trace this problem. Very time consuming and tedious work. And even when you do find the bad connector(s), you can't buy just new pins. Ferrari only sells the harness. So you'll have to make a jumper wire.
    BTW each car's ECU are coded to the immobolizer. If you want to switch ECUs amongst cars you also need to switch their immobolizers.
    I have been told that you also should not switch left & right side ECUs. They are coded one way once they are installed. If you switch sides then they will reconfigure once, but will cause problems if you switch again. Don't know this for sure, as we always mark the ECUs so they go back to where they were before.
  3. fatbillybob
    Aug 10, 2002
    29,220
    socal
    The alarm imobilizers have been trouble in 355's and 360's. Is there a way to gut these parts out and remove them? Cars are more likely to die on their owners because of these devices than get stolen by theives.
  4. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    You can reprogram the ECUs to remove their immobolizer dependency. Ferrarifixer (Phil) recently did one pair for me. We wanted the spare pair to work on any of the team race cars.
  5. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    To clarify...
    The RH ECU communicates via the immobiliser, to tell the LH ECU all is fine and it's ok to start...(This is one of 3 reasons I know of why the cars sometimes only start on one bank initially)
    If the LH ECU has 100% NEVER been used on the RH side, you can swap it into another car... but again... only the LH side, or it will be coded to that car forever now.
    If you swap the left and right over within the same car, the LH will now be coded the same as the RH side... the car will still start and run perfectly, but both ECU's are now locked to your car immobiliser units, and cannot be shared any more.
    The thing is... there is no way to be 100% sure that the LH ECU is a "Virgin"... even the factory may have been there already.
    And yes, I do have the ability to turn off immobiliser function, but I can't see a justifiable reason to do this for road cars.
  6. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Phil:
    Glad to see you computer is working again. So after the immobolizer function is turned off, can I remove the immobolizer circuit all together or do I still have to leave it in place?
    BTW did you also turn off the immobolizer function on my other two pairs of ECUs?
  7. fatbillybob
    Aug 10, 2002
    29,220
    socal
    Thanks Phil. Is the imobilizer circuit something that can be taken out of the car altogether? Is the IM coding soemthing that gets burned into the eprom on the ecu? You see I hate ALL ferrari electronics. I would rather wire in an aftermarket alarm/imobilizer that was reliable Japanese that rely on Ferrari and a AAA card with cellphone!
  8. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    I still can't confirm the exact wiring layout of the immobiliser as I simply haven't spent any time investigating it.
    I see no harm in trying to start/drive the car with the immobilisers unplugged now that your ECU's are set without them.
    If it starts and drives fine... rip out the boxes and as many wires as you can that are associated!!
    Yes, all 6 of your ECU's I recently handled are set with immobiliser off. But remember you have 3 different engine specs so don't swap them around unless you move the engine too!
  9. prospeked
    prospeked Rookie
    May 12, 2006
    11
    Australia
    Joe
    Ok, so let me see if i got this correct.
    I can swap the left hand ECU to between any 360 because it isnt linked to the immoboliser unless the ECU has been in the right side. If this is the case it is coded to the vehicle and cannot be used in another vehicle.
    Other than the immoboliser coding there is no issues with swapping the ECUs left to right on the 360?
  10. Rifledriver
    37,288
    None, but if you run the left one on the right side it will then be coded the same as the right one.
    If you ever need to replace the alarm module you will also need to replace one of the Motronics.
  11. fatbillybob
    Aug 10, 2002
    29,220
    socal
  12. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    L-L Yes, correct... But you MUST be 100% sure the ECU is a "virgin" before sharing... I think that effectively rules it out.
    Immob coding swap L-R... no worries at all. ECU's are identical.
  13. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    PM's exchanged with Rifledriver... he has the low down.
    But in summary... you must enable the ECU's to be programmed... this entails grounding a certain pin while powering others and connecting yet more to a "flux capacitor" thingo...(all very cloak and dagger and way over my head really)
    Then, you need a cyber geek with WAY too much keyboard time to know what to do next... but basically you need to search for a rolling random but kind of recognisable line of programming, and reset a certain part of it to be void...
    I've now done several sets for race cars... but unless you can prove an alarm system failure, I still can't see a justification for road cars.
  14. ferrariblue
    ferrariblue Formula Junior
    Jun 12, 2007
    548
    Houston, Texas
    Cody
    Just one question for you guys. My F dealer is now in the process of replacing my old alarm ecu with a new ecu "kit" from Ferrari. This is due to the failure of a 1st attempt to re-program a new set of alarm fobs with the existing unit in the car. The new kit has the alarm ecu, immobilizer interface and three new alarm fobs. There is no new Motronic engine ecu as a part of this kit, that I saw today. After reading the previous posts, will the new alarm ecu kit interface properly with the existing Motronic engine ecu? Or, will I have to shell out the bucks for a new Motronic as well? This stuff is confusing.
  15. FERRARI TECH 24
    Feb 15, 2007
    9
    Mt Airy N,C
    casey johnson
    YOU WOULD ONLY HAVE TO BUY A NEW ECU IF THE ECU'S HAVE AT ONE POINT BEEN SWAPPED SIDE TO SIDE. THAT WOULD CAUSE THE ONCE LEFT HAND ECU TO NOW BE MATED WITH THE OLD ALARM.
    IF IT IS A VIRGIN ECU YOU CAN SWAP IT TO THE RIGHT BANK WITH NO PROBLEMS IN YOUR NEW ALARM KIT.
  16. FERRARI TECH 24
    Feb 15, 2007
    9
    Mt Airy N,C
    casey johnson
    CHECK THE DIAGNOSTIC CONNECTOR BEHIND THE DASH ABOVE THE OBD2 SOCKET, IF IT IS UNPLUGGED IT WILL NOT COMMUNICATE WITH THE RIGHT HAND ECU. JUST PLUG IT BACK IN AND YOU SHOULD BE GOOD...JUST HAD THIS PROBLEM LAST WEEK!
  17. ferrariblue
    Jun 12, 2007
    548
    Houston, Texas
    Cody
    My 360 is 6 years old or so. I believe the existing alarm ECU was re-progammed with fobs once before a few years ago (before I had the car). This is also why I believe the re-program we tried to do with the new alarm fobs did not work. I'm assuming now that the F dealer knows that they will need to swap the ECU's from left to right and vice versa for this new alarm kit to interface properly. Out of curiousity, what would be the price of a new Motronic through Ferrari cost?
  18. FERRARI TECH 24
    Feb 15, 2007
    9
    Mt Airy N,C
    casey johnson
    APPROX 2,500.00 GIVE OR TAKE
