No crank after manual swap | FerrariChat
Discussion in '360/430' started by imahorse, May 19, 2023.
  1. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    Hey guys, I've been chasing this problem on my 2000 360 for a bit now and could really use a hand. I am stocked up on food, cigars, and alcohol and will have most of the weekend to work on sorting this out and would like some additional ideas to try. For the past year and a half I pieced together/fabricated a manual conversion. When that was complete, I attempted to start the car and I got a no crank condition. Just silence. 360trev has been really helpful as we went through this and we tried multiple ecu flashes to make sure that is not the problem. As of now, the immobilizer is completely bypassed. The puzzling part is I really didn't do much with wiring. I know the car won't start as F1 if it doesn't register that the system is pressurized. I figured pulling the system and the TCU would bypass this with the manual ECU flash. Am I missing something? I'm led to believe that the no crank and no fuel pressure issue is connected.
    Here is what I know:
    - The brake switch is working
    - The gas pedal and throttle bodies are working
    - There is no fuel pressure
    - Sometimes the check ok will illuminate on the dash, sometimes it won't
    - There are no error codes in the ecus
    - Everything in the swap appears to be working
    - I checked almost all of the fuses and they are good
    - I swapped the starter relay with a different relay
    - The inertia switch is in place
    - The clutch engages and disengages properly according to the diagnostic tool
    - The rear grill and bumper are removed
    - There was an issue where the decklid wouldn't register as closed on the cluster screen, but it appears to be working now
    - I did not remove the F1 wiring harness, just the components
    - I broke a small ground on the top rear of the engine. I soldered and heatshrunk a new one in
    - The acceleration sensors got a little banged up as I forgot to remove them before attempting to pull the transmission
    Things I did since the car last ran:
    - Pulled the transmission to reseal the TOB for the swap
    - Removed the front bumper to put in challenge grills
    - Disassembled steering column to put in gated column trim and remove paddles
    - Install a cat back exhaust
    - Remove a couple extra speakers from the fast and furious stereo install
    Things to try:
    -Testing fuel pump with diagnostic tool if possible
    -Different battery
    -Checking the few fuses I haven't
    -Changing important fuses regardless of how they look
    -Break down in a drunken sobbing mess and plead with it
    -Double check brake switch
    -Sacrifice small animals to old pagan gods in hopes the car runs again
    -Reinstall F1 power unit
    -Check for power from starter
    Anything else I should add to my list?
    cavlino likes this.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,218
    East Bay, California
    Joe
    Any chance that the immobilizer in the key needs to be re-paired with the system or something related?
  3. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    Immobilizer was the initial suspect and is completely bypassed
  4. brogenville
    brogenville Formula 3
    2,269
    Robin
    Ground out pin 42 on the big tcu connector.
    Qavion, 360trev and imahorse like this.
  5. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    imahorse likes this.
  6. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    Thanks guys! I'll give that a shot in a few hours here
  7. Qavion
    Qavion F1 World Champ
    14,342
    Ian Riddell
    Did you use a jumper plug on this connector as part of the mod?
    (behind the driver)
    Normally the connector (held in Mr @Toonfosi 's hand) goes to the F1 TCU, but the short white wire jumper (installed as shown) bypasses the TCU and goes straight to the starter relay.
    OEM gated cars have this jumper.
    brogenville, LorenzoR and imahorse like this.
  8. Qavion
    14,342
    Ian Riddell
  9. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    I did not. I did nothing with bypassing the TCU. Will jumping that connection have the same effect as grounding pin #42 on the large TCU harness?
  10. Qavion
    14,342
    Ian Riddell
    Sorry for the delay... had to check.... YES.
    brogenville and imahorse like this.
  11. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    No worries on the delay! I'm still at work anxiously awaiting going home and trying to start my car! [emoji28]
    Qavion and brogenville like this.
  12. Parari
    Parari Rookie
    Apr 3, 2022
    8
    JAPAN
  13. Qavion
    14,342
    Ian Riddell
    #13 Qavion, May 19, 2023
    Thanks for the reminder, @Parari
    The F1 has a 4 pin plug. The manual car has a two pin plug. You have to short out the middle 2 wires. i.e. pins 2 & 3.
    Buying a manual car jumper wouldn't have helped.
  14. Qavion
    14,342
    Ian Riddell
    Dang..... Hold your horses.... You said you had the immobiliser delete. That jumper is only used if you still have a functioning immobiliser.
    Recomputing....
  15. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    Well ****
    I'll still try it anyways.
  16. Qavion
    14,342
    Ian Riddell
    #16 Qavion, May 19, 2023
    You can disconnect the jumper plug and short pin 2 to earth.
    Don't loop the wire, just connect pin 2 to earth. i.e. the grey wire on the fixed, bottom half of the plug.
    An earth/ground on that grey wire provides an earth for the starter relay coil. All the starter relay coil then needs is power from the ignition switch (when you turn the key to start).
    This technique has been used before on FCars. Don't think it's "experimental".
    If you have an OEM charger, be sure to disconnect that before trying to start the car.
  17. Qavion
    14,342
    Ian Riddell
    Specifically, on manual conversions, I mean.
  18. Qavion
    14,342
    Ian Riddell
    The chance of success would depend on how much of your immobiliser system has been deleted :p
  19. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    Much appreciated! At this point I'll try just about anything lol.
    Qavion likes this.
  20. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
  21. Qavion
    14,342
    Ian Riddell
    YAY
    Did the loop method work or did you just ground out pin 2?
  22. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    I grounded out pin #2!
    Qavion likes this.
  23. Qavion
    14,342
    Ian Riddell
    Actually, after rechecking, both the F1 and 6-speed cars have 4 pin plugs. I thought one plug looked bigger in the photos, but they are the same size.
    I wonder if there is a part number for the OEM jumper plug.
  24. imahorse
    imahorse F1 Rookie
    4,363
    WI
    Dustin
    It's easy enough to make one. I made a wire for it in 5 minutes. I'll create a better solution in the near future. Thanks again. I am beyond ecstatic the car is running again after a year and a half. Everything else worked perfectly.
    brogenville, cavlino, kes7u and 3 others like this.
  25. Qavion
    14,342
    Ian Riddell
    #25 Qavion, May 19, 2023
    Creating a jumper plug/ground wire at that point is probably a bit neater than adding an earth to the F1 TCU plug.
    I believe this TE Connectivity Multilock plug might do the job...
    https://il.rsdelivers.com/product/te-connectivity/174922-1/te-connectivity-multilock-070-male-connector-35mm/1639419
    I made up a roof bypass harness for F355's using a 6 pin version of this plug.
    You'll need some sockets (?) to go with this. Anyway, whatever contacts are on the plug half with the clip on it (OEM two wire half).
    https://il.rsdelivers.com/product/te-connectivity/175027-6/te-connectivity-multilock-070-female-crimp-16awg-6/7122188
    You only need one socket, but you might have problems buying just one. I think Element 14 in the UK might sell you one... but it's probably best if you have some to practice with crimping these. Note: Postage prices are crazy at RS Components (I've found)
    and you'll need some good crimping/wire stripping tools.
