430 - No Door Locks | FerrariChat
430 No Door Locks
Discussion in '360/430' started by LorenzoR, Jan 27, 2025.
  1. LorenzoR
    LorenzoR F1 Rookie
    After 2 months of being away from the car, with it on a maintainer, I don't hear the door locks locking and unlocking when I press the key fob any ideas appreciate it.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    What do the lights in tender say /show
    Are the fob batteries ok ..
    If you use the key to turn door lock do you hear the whole car unlock
  3. LorenzoR
    LorenzoR F1 Rookie
    the batteries in the fob are probably 2 years old. When I get back home in an hour I'll try the other fob and check the maintainer. Fyi the main battery is 3 months old
    flash32 likes this.
  4. LorenzoR
    LorenzoR F1 Rookie
    I should mention that i've been driving the car about 4 or 5 times. But they still don't work
  5. GogglesPisano
    GogglesPisano F1 Rookie
    3,213
    East Bay, California
    Joe
    Does the lock on the interior handle work?
  6. LorenzoR
    LorenzoR F1 Rookie
    No it doesn't. Checked both sides and no dice
  7. LorenzoR
    LorenzoR F1 Rookie
  8. LorenzoR
    LorenzoR F1 Rookie
    O k if I turn the key to the right like this, I hear a constant click click click coming from under the dash, and it keeps clicking until I turn it all the way to the left. And either way I turn the key i don't it lock
  9. LorenzoR
    LorenzoR F1 Rookie
    Ok so i zeroed in on it. i was listening for the clicking. As I listen, the lock mechanism up and down and I found that it was coming from the driver's side left footwell. so all I did was pull the carpet out a little bit and the doors locked. so apparently something is loose, and i'm hoping it's just a loose wire back there
    mwstewart and Qavion like this.
  10. Qavion
    Qavion F1 World Champ
    14,321
    Ian Riddell
    That’s where the Window ECU is, so there will be a lot of door-related wiring there. Check for ECU plug security and that the pins and sockets are not contaminated. Most power wires are on the top plug.
    JaguarXJ6 likes this.
  11. LorenzoR
    LorenzoR F1 Rookie
    Thanks Ian I appreciate that info. I have a feeling it's just a pin that may have some corrosion. It’s amazing what will happen after being away from the car. I think what I'll do is tomorrow i'll shut the power off to the car and unplug those plugs a couple times. Maybe that will scrape off any possible corrosion that may be there. I'll keep the threads updated Thanks
    Qavion likes this.
  12. colorfull
    colorfull Formula 3
    2,340
    Franklin Park, New Jersey
    John Napoli
    Wow, glad you got it sorted
    LorenzoR likes this.
