No Laughing!!! First Custom 355!! | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by 285ferrari, Jun 20, 2007.
  1. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    #1 285ferrari, Jun 20, 2007
    Ok I thought I post this in it's own thread because I am somewhat proud, but also disappointed it didn't turn out any better. Started off as a red/black UT 355 Spider. This is my FIRST attempt at repainting a model.
    Came apart fairly easy. Getting the steering wheel back in and snapping into the column along with keeping it hooked to the front suspension so the wheels would turn with the steering wheel was a pain in the rear!!!
    Also I had 2 screws left over--not sure where they bacl, but the model is tight and not loose anywhere. Next time I will take pics off each part as I remove it so I know where it goes back.
    Do you guys cover up the front Ferrari symbol, Pininfarina side badges, rear Ferrari logo, etc?? I tryed to use painters tape to tape those over, but didn't work that well--just so small.. Anyway I sanded down the car, primed with white paint and sprayed the blue over that. Then sprayed a few coats of clear. Used flat black on the rear to give a Challenge grill look. At this point--Do you guys wet sand and buff the whole car? I just left it as is because I figured I would screw the paint up. Anyway--here it is!!
  2. 4REphotographer
    4REphotographer F1 Veteran
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    that looks really good, i hope my first comes out that good, i like the challenge grill its one thing im putting on mine along with scuderia shields
  3. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    It is just so difficult working with small pieces--I guess after a few I will get the hang of it. Anyone have paint procedures they would like to sahre. xactly how many coats, the sanding process, etc..That is my biggest goof--Not having a nice shiny paint coat..
  4. F355guy
    F355guy Karting
    Dec 19, 2003
    231
    John P.
    Looks good! not bad.
  5. ROBIN222
    ROBIN222 Karting
    Apr 4, 2006
    84
    Taiwan
    ROBIN YANG
    Hi,Robbie
    Looks awesome!!! not bad at all! The color just like Mike's F355.
    But it seems a little bit waste to repaint a UT F355 spider.
    My suggestion,you may use a HW F355 to do the repaint job.
    About the emblems,you may buy some from ebay.
    Hope you will keep going on this way of modification since you have made the 1st step.
    Congratulation!!!!
  6. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    I got the UT for $20 off Ebay--wasn't new in the box...
  7. JOEV
    JOEV F1 Rookie
    Aug 6, 2003
    2,827
    Ontario, Canada
    Joe
    It's definitely nice, especially since it's your first one.
    Check out the tutorials here http://www.briansmodelcars.com/tutorials/index and here http://italianhorses.net/Tutorials/tutorials.htm
    Some helpful FChat threads
    http://www.thebestemployee.com/forum/showthread.php?t=100500
    http://www.thebestemployee.com/forum/showthread.php?t=50543
    Lot of guys here have done amazing re-paints on their 1/18s.
    BTW - I like the photo booth tutorial because I think one of the hardest things about taking pics of models is that the lighting (natural or flash) makes it really hard to fully appreciate the paint job.
  8. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    Some great info there--THANKS!! jOE!!
  9. moriaan1
    moriaan1 Formula 3
    Dec 3, 2006
    2,330
    Netherlands
    Hans
    Did you cover the colorcoat with a clearcoat?
    metalic paint allways needs a clearcoat to make it shine.
    Most bulders use on all their modells a clearcoat.
    It also depends on the modell.
    I build large older modells (at the moment a P3 in 1/12)
    To make them look authentic, I never use a clearcoat on non metalic colors.
    The numbers of layers depends on the color and the paint.
    When you use a metalic, just get color deep and covering, that takes about 6 layers.
    The clearcoat is a different matter.
    After 3 coats(take time in between to let it dry a bit).
    Give it a thicker layer, to make it shine(not to much otherwise its running).
    Leave the modell for 3 days and buff it up, polishing away the toplayer of the clear and any imperfections, this way you'll bring out the perfect shine and completion of the procedure.
    I must say, for a first try your modell looks good!
    No detail is lost, and the surface is without any imperfections.
    After 20 years of building, now and then I mess up being impatient now and then. But no worry metal and resin modells can be cleaned to start over again.
  10. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Nice work! I like the color.
  11. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    Thanks for the info!! It is a metallic color and yyes I sprayed 2 coats of clear on it..
  12. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    Where?? Any links ??
  13. ROBIN222
    ROBIN222 Karting
    Apr 4, 2006
    84
    Taiwan
    ROBIN YANG
  14. LambogatiINC
    LambogatiINC Formula 3
    Aug 14, 2004
    1,307
    Toronto/Chicago
    Sal
    robbie for your first time that thing turned out spectacular!
    my first paint job was horrible lol, i wrote off the model and now use it for parts!
    i tried it on a 1:18 murcielago i got at a toy factory sale for 7 dollars, needless to say urs looks great...
  15. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
  16. fiorano94
    fiorano94 F1 Veteran
    May 26, 2006
    6,892
    MW/NW/SE
    Rob,
    Could you give step-by-step instructions on taking apart a UT spider?
    I have one i may paint.
    Thanks.
  17. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    It is actually fairly straight forward---When you flip it over--you will see screws--Remove all of them---I only had to drill out 2 parts if I remember correctly to get it all to come apart. Once you start taking the screws out--You will see which parts need to be drilled out and will not come apart easily..My next will be a HW model and I heard they are the toughest to get apart...
  18. Gimme Fuel
    Gimme Fuel F1 Veteran
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    285 dude.
    I've got a bunch of decals for your model if you like.
    I had em' custom made when I was in the painting model business a while back. a set of decals includes; bonnet badge and 2 fender shields.
    They are meant for 1/18 models, and you need to put em' in water to make it work. so if you'd like a couple of sets just let me know and I'll send em' out to you! :)
    Cheers
  19. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    Paul--PM sent..
  20. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    Got it :)
    Sending out some decals for you on Monday :)
  21. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,167
    Wash DC area
    Robert
    Robbie,
    Good job man! Turned out much better than I was expecting! I like the challenge grill job!
    Robert
  22. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    Awesome--Paul--you are the MAN!!
  23. ROBIN222
    ROBIN222 Karting
    Apr 4, 2006
    84
    Taiwan
    ROBIN YANG
    I did buy the Ferrari emblem decals from this store.
    You may ask him for the detail even it's not listed on his auctions.
    It's ok to communicate in English.
  24. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    sounds good--message sent to him..
  25. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    Just got a HW 355 GTS --- the put together one---would like to do it a different color. How do you guys paint around the Pininfarina and front Fcar logo?? Very small pieces of tape?? How do you sand the model down and ready it for paint w/o sanding off those badges??
