No Power | FerrariChat
No Power
Discussion in '360/430' started by Kre8tive202, Dec 23, 2013.
  1. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    Hello everyone,
    I would like some advice. I own a 2000 360. I drove it around town approximately a week ago. Yesterday I go to open the driver side door and I dont hear anything. I normally hear the F1 pump prime. I found out the car was completely dead and had no power. So I hooked it up to the trickle charger but after 24 hours, still not one glimmer of power in the car. What could have possibly gone wrong. I drove it parked it and did nothing else. Any advice,before I go tearing through everything.
    Thanks,
    Mario
  2. Dano360NC
    Dano360NC Karting
    Aug 11, 2012
    167
    Southeastern PA
    Dan
    Did you access the battery compartment and check the cable connections? Any chance the disconnect switch under the front bonnet got turned to the disconnect position?
  3. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    Have not checked anything yet just plugged in the trickle charger. I was thinking the same thing that maybe through some weird vibration, the knob turned and it switched to the off position. I can only imagine that it is something simple as I have done nothing to the car except for drive it and park it.
  4. Fatty
    Fatty Karting
    Jun 5, 2010
    235
    Australia
  5. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    Even when I put the key in the ignition and turn it to the first position, I get nothing at all. No lights nothing....
  6. Fatty
    Fatty Karting
    Jun 5, 2010
    235
    Australia
    Ouch. Something more sinister (hopefully not)...
    Like you mentioned, check the battery cut off switch first.
    Secondly, crawl until the passenger side, and pop open the kick panel (two allen-key type screws), and check the battery and/or battery connections.
    Nothing else I can think of as yet, until you do that.
    good luck
  7. vrsurgeon
    vrsurgeon F1 World Champ
    16,527
    Charleston, SC
    Curt
    Firstly, the trickle charger won't recharge the battery.. it will only maintain it. Take the battery out and then charge it a day/overnight with a regular charger.
    Once it's recharged and working.. then use it to diagnose the alarm module toast, or other short in the car that's draining power. If it's 3 years or older you may have to replace the battery..
  8. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,334
    NJ
    RMani
    when you said you hooked it up to the trickle charger do you mean you just plugged in the battery tender? because that won't charge the battery only maintain it's current level. if you are using an actual charger i'd just swap the battery and see if that solves the problem. maybe it's so badly damaged for whatever reason that it's completely useless.
  9. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    I agree I am under the assumption that the trickle charger will recharge the battery. I will have to remove the battery and charge it back up to atleast check off any battery issues.
  10. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    That is what I am starting to think. It has died atleast three times this year. Anyone know if I can buy a battery for it at my local auto parts store like OReilly or should I just get one from an online store. I like the idea of replacing it with a dry cell battery.
  11. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    I agree, I have to go back to the basics;
    -Good battery first
    -Good connections
  12. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,858
    San Jose, California
    Just throw an Interstate battery in there, it will be fine.
  13. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,334
    NJ
    RMani
    any regular battery will work. i'd go with the least expensive option possible, especially since you're not 100% sure the battery is the issue.
  14. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    Whew sounds good glad to hear it. I will be at the auto parts store as soon as they open. My Christmas Eve will not be right knowing my 360 is in my garage and not working...ugh
  15. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
  16. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
  17. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    Don't bother with Costco. The Pittsburgh location doesn't carry it.
  18. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
  19. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    Good morning everyone,
    I am happy to say that she is "BACK." I came home late last night from work and could help myself and had to do a little poking around at 3am. I popped the hood and pulled the manual hood release, turned the master switch to the "off" position and heard one loud beep from the car. I then turned it back to "on" and the car powered up. Although it was weak. I opened the driver side door and I could hear the F1 pump try to prime but again it was weak. So I connected my STANLEY Automatic Charger/Maintainer and left it overnight. Woke up this morning went down stairs and opened the driver side door. The F1 pump primed like a jet getting ready to take off. This was music to my ears. Got in and she kicked over just fine....my son did tell me that he noticed the engine lid not latched yesterday. It then dawned on me that I open the engine lid a couple days ago and must not have closed it to where it latched. Can this kill the battery?
  20. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    In the past my trickle charger has brought it back up to charge, it just took a little longer than a dedicated charger.
  21. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    I was thinking that, maybe the Tracy one?
  22. Manila360
    Manila360 Karting
    Dec 16, 2010
    97
    Probably a dead battery. When a battery is totally dead, no amount of charging will be able to bring it back to life
  23. Kre8tive202
    Kre8tive202 Rookie
    Dec 29, 2012
    18
    Discovery Bay
    Mario Garcia
    I got the battery back but I can only imagine the battery will not hold up much longer. Will be looking for a suitable replacement. Possibly a dry cell with 50% less weight.
  24. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    I would give them a call first but I doubt it. Good luck!
  25. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    That shouldn't have any effect as there is no light in there to drain the battery. The switch for the hatch is only there to prevent you from putting the car in gear with it open.
    Alan
