No response on 430 top problem | FerrariChat
Discussion in 'Technical Q&A' started by wlracing, Sep 20, 2015.
  1. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Any help with functions of all the various micro switches involved with 430 top closure so that I can fault find my top failing to close ?
  2. hessank
    hessank Formula 3
    1,903
    Canada, Florida
    Fred
    #2 hessank, Sep 20, 2015
    What is the alarm showing on the dash? Is it showing as fully or partially open?
    Does it beep at you as soon as you push the button?
    Have you verified that your fluid level is correct?
  3. hessank
    hessank Formula 3
    1,903
    Canada, Florida
    Fred
    #3 hessank, Sep 20, 2015
  4. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Hi Fred,
    Thank you for your reply . There is no alarm or beeping and the display is normal showing top closing .
    I have checked the fluid level and it is correct . The top is not jamed as when I see it is not going to close so release the operating switch the top then pops up around 1 inch , if I then reverse the switch top goes down hatch closes and flaps and windows go up as normal .
    I Have checked micro switchs on l/h flap are operating ok , I suspect another micro switch but do not know where to look .
  5. vrsurgeon
    vrsurgeon F1 World Champ
    16,488
    Charleston, SC
    Curt
  6. racer
    racer Karting
    Nov 17, 2003
    196
    Atlanta
    Ron
    What you are describing is the top not folding correctly during closing. The roof cross bars must be in the correct position for it close fully to allow the clam shell cover the come down and side wings to go up. check the elastic on the cross bars/bow bars in diagram #115 it doesn't have part number but bolt #11 holds it in place. if this bars is not folded correctly the top won't close fully. Without a diagnostic tool and knowledge of how it all works its almost impossible to tell whats wrong. Good luck
  7. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Thank you for replies . Problem was not one of not closing properly just not trying to close , appeares it was to hot as now working perfect again after cooling down . Surprised as have had car 7 years and only happend this year .
