No reverse from neutral when hot F1 | FerrariChat
Discussion in '360/430' started by CPais, May 13, 2009.
  1. CPais
    CPais Rookie
    Sep 30, 2008
    44
    CA
    My F1 transmission does not want to go into reverse from neutral when the car is hot. When it's cold it works no problem. It will go into reverse from 1st when it's hot, just not from neutral. Also, if you try to go into reverse from neutral when hot the indicator won't go to reverse but, if you rev the engine it wants to stall until you put it into neutral with both paddles even though the indicator says neutral all the time. When the car is off and the key is on it will go into reverse from neutral everytime. Any ideas?
  2. Fmax
    Fmax Formula Junior
    Aug 16, 2007
    799
    Prague, CZ
    Max
    Clutch on the way out possibly. First sign in a ferrari is the shifting probs. How many miles has the car done?
  3. SandmanF1
    SandmanF1 Karting
    Jun 13, 2008
    66
    Los Angeles
    NA
    There are a few different threads related to this same issue. Seems to be a problem with 05 and 06 F1 transmissions. Is your car from either of those MYs?
  4. CPais
    CPais Rookie
    Sep 30, 2008
    44
    CA
    It's an 04. I searched through the threads and have not found anything in regards to this issue with going into reverse.
  5. Fmax
    Fmax Formula Junior
    Aug 16, 2007
    799
    Prague, CZ
    Max
    #5 Fmax, May 13, 2009
    A friend of mine had trouble getting into second when hot but fine for the first 20 miles. There is a special tool ferrari can use to reset the pin that changes the gears, he had to take it off and do it manually. Took him 6 tries. I would take it to someone who knows, perhaps it is something as resetting tension on a cable but come to think of it it sounds like the same problem he had.
  6. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    Had the same issue on my 2007 F430............it was simply a faulty reverse button which is on the center console. It was changed and it's been ok ever since.
  7. mooose
    mooose Karting
    May 27, 2008
    118
    the slippage on the clutch just needs to be adjusted.
  8. frvett
    frvett Rookie
    Feb 2, 2008
    39
    I have the same problem on a 2000 - 360 with 14,000 miles on the clutch replaced in 2004. Have not had a chance to take it into ferrari daeler in Orlando yet will in a couple of weeks. Just responding others having the same problem I think it might be the clutch needs replacing.
  9. domi
    domi Rookie
    Mar 6, 2008
    38
    Dominique
    Hi Cpais,
    I own a 2002 360 spider and i have had EXACTLY the same problem since 14 months. I have done 7000 km and i live with it. I don't think it is related to the reverse button or the clutch wear (mine is 20% and i did a PIS adjusment in F dealer), but my mechanic told me most probably some air bubbles in the F1 transmission fluid. I've been told the transmission needs more power to engage reverse from neutral rather than from the first gear, so i assume that when hot, the lack of pressure due to air in circuit (or other reason?) does not allow the transmission to fully engage reverse from neutral (only partially which makes the engine stall when accelerating).
    Please, let us know if you find anything out.
  10. the_wanderer
    the_wanderer Rookie
    Jun 4, 2008
    1
    Hi guys,
    Been having exactly the same problem on a 2002 360 spider as well (clutch wear was at 14% a couple of months ago).
    Cheers
  11. Art's 430
    Art's 430 Rookie
    Apr 1, 2009
    43
    IL
    Arthur
    I had the same problem on my 05 430. The dealer said that the acuator screws needed to be alinged and bleed.
    I was also told that if the problem continues it may be the thrust bearings
    And on a 430 that can be north of 10k. I haven't had any problems since the first repair
    But I thought I would share my experiance.
  12. CPais
    CPais Rookie
    Sep 30, 2008
    44
    CA
    Thanks for all the replies. I will try and diagnose and figure this problem out so maybe I can help come up with a solution for everyone.
  13. Judge
    Judge Karting
    Aug 14, 2007
    54
    SF Bay Area
    I have the same problem on my 07 430. I cant even get it into reverse from first until it cools down. Have not taken to the dealer for a first service yet so dont know what they say.
  14. domi
    domi Rookie
    Mar 6, 2008
    38
    Dominique
    Hi Cpais,
    Did you ( or anyone) figure out this problem?
  15. elmani
    elmani Formula Junior
    Oct 7, 2008
    253
    austin Texas
    marc b
    I like domi's explanation... i think it is most probable ... on my 2002 F360F1 spider, i v had this problem for many months now and living with it... hope to get an answer soon.
  16. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,957
    #16 MalibuGuy, Aug 29, 2009
    If you cannot engage reverse from neutral, engage 1st gear and then you should be able to engage reverse. I've had this problem for a while too. The clutch and throwout bearing are fine so I don't think that is the issue.
  17. Art's 430
    Art's 430 Rookie
    Apr 1, 2009
    43
    IL
    Arthur
    I had the same problem, dealer bleed the
    actator screws still didn't fix it. We replaced
    the actuator f1 lines and pump and now the car
    is perfect. The repair was $16000 on a 2005 430
    thank god the car was under warantee.
  18. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,473
    wow 16k makes me sometimes not want a f1 and get a 6spd for reliabilty concerns.glad u had warranty.
  19. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I'm with you-- sounds like you shouldn't get an F1 gearbox unless you consider $16K to be pocket change.
  20. Art's 430
    Art's 430 Rookie
    Apr 1, 2009
    43
    IL
    Arthur
    Yea I agree very expensive to repair but everything
    on these cars are expensive. I owned a 3 pedal before this
    car and now I would never go back.
  21. frvett
    frvett Rookie
    Feb 2, 2008
    39
    I have a 2000 360 with 7000 miles on clutch and had it into Ferrari Central Fl. and they changed the F1 fluid and checked out clutch wear it was 50%. Could not find anything else wrong without taking the clutch out. They feal the pressure plate springs are getting weak
    causing the problem. I question this opinion? I am going to live with it I just put in 1st then reverse and it works fine. I have no slipage in starting or when shifting I don't think it is a pressure plate problem.
  22. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    I also had this problem a couple of times when I had my 360. My clutch was new. The solution for me was going from 1st to Reverse instead of Neutral to Reverse.
