No turn signals ?? | FerrariChat
No turn signals ??
Discussion in '360/430' started by Falcon Wing, Jun 13, 2017.
  1. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    I noticed tonight that my turn signals were not working. (called dipped lights in the manual)
    I removed the fuses and they looked fine.
    I checked 20-A15, and 23-A5, and 24-A5.
    Any other ideas? Replace the relay?
  2. MalcQV
    MalcQV F1 Rookie
    Oct 11, 2004
    3,292
    Manchester, UK
    Malc Holden
    Dipped lights called turn signals? Dipped [head]lights usually means your normal headlight i.e lights you use at night.
    Indicator is a term I have seen for turn signals.
  3. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    #3 Falcon Wing, Jun 13, 2017
    No mention of "indicator" lights in the fuse labeling section of the manual....
    To be thorough, I checked all of the fuses...all intact.
    I then swapped the "position lights" relay with the "parking lights" relay and the parking lights still worked, so its not the relay....if "position lights" means indicators???
    I am a bit stumped. What else could it be?
  4. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
  5. hessank
    hessank Formula 3
    1,928
    Canada, Florida
    Fred
    Yes, that's what they're called in the manual.
    Crazy but true.
  6. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    #6 Falcon Wing, Jun 13, 2017
    Just got word from Ricambi that they are temporarily removed from inventory.
    Anyone else have a suggestion to obtain part 213326?
  7. vrsurgeon
    vrsurgeon F1 World Champ
    16,540
    Charleston, SC
    Curt
  8. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    That would be nice if that worked....
    I've contact a few online retailers and they cost is ~$200+, although none have gotten back to me.
    Ferrari dealer was $640.
    I wonder if Fiat dealer has it cheaper...
  9. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    628
    Eden Prairie, MN
    Matt
    I have a relay i bought from Racambi last year when I was having a similar issue, turned out to be a nick in the wiring. Will sell to you if you want
  10. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    PM SENT!
  11. Falcon Wing
    Aug 4, 2010
    1,294
    Colorado Springs
    #11 Falcon Wing, Jun 21, 2017
    It turned out that the flasher relay that is under the glove box was culprit.
    As soon as the new one was installed, everything was back to normal.
    Thanks to fellow fchaters for saving me a bunch!
    If you look at Pic #2 here...you can see some corrosion on the mounting bracket. Does anyone know if any of the A/C condensation would run past where the relay is located?
    Mine went out after using the A/C for the longest I have ever used it (25 -30 min), as most of the time I just have the top down.... Probably just a coincidence, but just wondering.
  12. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    519
    Where did you end up finding a relay?
