Noisy 308 shifter - Help! | FerrariChat
Discussion in 'Chicago' started by tifosi12, Mar 27, 2005.
  1. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,826
    @ the wheel
    Andreas
    It seems the H shifter in my 308 dried out over the winter: When moving it sideways or back/forth it makes some screeching sounds. Any advice on what to pour into it? I'd just drip some WD-40 down into the H. Comments?
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Andreas-
    Can you be more specific; are you talking about the gear shift lever?
    If WD-40 hasn't solved the problem; you can drop by Ed's on Wed. nite after 6PM.
    Wed. night we usually work on our own cars, and just kind of hang out drinking beer. :)
    Let me know if you want to come by.
  3. tifosi12
    Oct 3, 2002
    49,826
    @ the wheel
    Andreas
    Skip, not sure how I can be more specific: The linkages just below the chromed H plate are cranking. They're very sticky as if dried up so any movement of the shift stick is followed by a slight screech.
    But it sounds like you're not opposed to WD-40 so I'll give it a shot.
  4. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    May just need a good cleaning. A lot of crud gets in there since there's no boot for the shifter.
    Take off the shift gate and see if you can clean things up a bit.
  5. tifosi12
    Oct 3, 2002
    49,826
    @ the wheel
    Andreas
    Thanks, will do.
    Just talked to Dave who recommended White Grease over WD-40.
  6. tifosi12
    Oct 3, 2002
    49,826
    @ the wheel
    Andreas
    Took the shifter plate off today and started digging. Unreal all the dirt that has accumulated in there. Aside from some of Luigi's cigarette butts and Enzo's purple ink pen there was half a cat of fur. It felt like cleaning out some public toilet's plumbing.
    Well anyway, it's all clean and greased now. No more noise. Maybe you guys want to check out your shifter, you'll be surprised at all the gunk you'll find in there.
  7. FerrariFrank1
    FerrariFrank1 F1 Rookie
    Aug 15, 2003
    3,887
    Chicago-Phoenix-L.A.
    Frank
    HeeHee!!!!!!....:)
  8. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Andreas-
    Glad it was nothing serious.
  9. tifosi12
    Oct 3, 2002
    49,826
    @ the wheel
    Andreas
    Well, the gremlins just hopped over to the other car: Just walked back after I had to emergency drop it off at a car shop. The fun never stops. At least the engine came back to life after half a year of being mothballed.
  10. FerrariFrank1
    Aug 15, 2003
    3,887
    Frank
    Yes,I have gone all over my Car,replaced all of the Fuses,(and saved the old ones as Spares) Cleaned the Connections,Lubed as needed,(and where I can fit my big old hands in....:( ) Checked all hose clamps,ETC....It is good to do every Spring....I have seen way too many Burnt Rear ends of 308's on "Wrecked Exotics" website....:(
    But,I need to get a Service manual. Anyone have a good source?
  11. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    348 has a gator that surrounds the gear lever. Can be made to fit 308 and stop "foreign matter" going in there.
    Philip
  12. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    You should get that car to Ed too. If it's not drivable, arrangements can be made to have it flat bedded to him.
  13. tifosi12
    Oct 3, 2002
    49,826
    @ the wheel
    Andreas
    It got fixed and drives again. It needs a ton of TLC, detail work and some real Vette tinkering (3 point belt conversion, A/C etc). You think Ed is up to speed on old Vettes? It's one thing to work on the engine of a Ferrari, but hey it is brain surgery to fix up a Vette.
  14. FerrariFrank1
    Aug 15, 2003
    3,887
    Frank
    Chevy Smallblocks are as easy as Lawnmower engines....:) Basically the same since the early 1950's when they came out. Let me have a Look at her sometime. Also,look in those Corvette Parts Catalogs that you are probably getting by now for parts.
    Speaking of Small Block Chevy Motors....I saw one of those "Boss Hoss" Motorcycles yesterday,that has one of those engines in it. Unbelievable...a Big,Car Engine in a Motorcycle. That Gas Tank was almost 2 Ft. wide! It's gotta be heavy.
  15. tifosi12
    Oct 3, 2002
    49,826
    @ the wheel
    Andreas
    The engine is fine, it's the stuff around the engine, that has issues. I think that part is called "the car".
    And it's not the Chevy parts that need fixing, if you catch my drift.
  16. FerrariFrank1
    Aug 15, 2003
    3,887
    Frank
    LOL! Yeah. Hey,I'd still like to check her out sometime. I had 4 of the C3 -'68-'82 Style Corvettes,and maybe can be of some help....:)
  17. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Very much so, Ed knows old Corvettes. He's done mechanical restorations on a few.
    It's like one-stop shopping when you bring your car to Ed. We also have a friend that does excellent body and paint work, if it needs it.
    Give Ed a call; I'm sure he can have everything taken care of!
  18. FerrariFrank1
    Aug 15, 2003
    3,887
    Frank
    ...........Enzo's Purple Pen.............:)
