Non Ferrari Steering Issue | FerrariChat
Discussion in 'Technical Q&A' started by PT 328, Aug 25, 2008.
  1. PT 328
    PT 328 F1 Rookie
    4,010
    #1 PT 328, Aug 25, 2008
    My neighbor has a Lexus RX 350. When making a right hand turn his steering wheel stays in the right hand turn position and is difficult ( stiff )to turn back to the left. This mainly happens when making a right hand turn. He is having no additional symptoms other than the stiffness. No grinding, squealing, loose steering. It is at the shop now and they are telling him it may be a strut problem. I knew someone on here could provide some more accurate insight into why this is happening. Thoughts? Thanks in advance for your help.
    Dan
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
  3. PT 328
    PT 328 F1 Rookie
    4,010
    Already gave it a shot and came up empty ( so far ). Thanks for the tip though. I am curious to the reason as well as my wife drives a RX330.
  4. MaleficVTwin
    MaleficVTwin F1 Rookie
    Jun 5, 2006
    4,312
    Reno NV
    Matt
    Strut problem is a possibility, but I would also look at the steering gear itself. It could be hanging up at full lock on that side. Good luck. :)
  5. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Dan,
    I was in the foreign car repair and restoration business for over 20 years and saw a couple of Toyota's and Volvo's with this exact problem. The problem is either within the steering rack, or the upper strut mount on the RHS is seized.
    With the car on an alignment rack...and the front wheels on "turntables", disonnect the tie road end at the right front wheel. Turn the steering wheel to the right and the left; if the steering now feels normal, the problem is within the strut bearing on the RHS. This can be further verified by turning the RH wheel, with it disconnected from the steering rack, by hand. With the car still on the turntables, the RF wheel should turn with ease.
    Conversely, if the wheel does move easily, the problem is within the steering rack.
    Regards,
    David
  6. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    SAAB used GM racks in the 80's, and they were notorious for doing the same thing. The rack cylinder would become worn and either jam under load, or bypass fluid and lock up. The harder you tried to turn it back the harder it fought. Disconnecting the tie rods would take the load off and make you think the trouble was elsewhere. Never heard of a strut bearing locking up but with the crap they build these days I can believe anything.
  7. PT 328
    PT 328 F1 Rookie
    4,010
    Hey Guys,
    Thanks for the insight. I will forward this to my neighbor. He will appreciate your thoughts. I will keep you posted as to the outcome. I knew this board would come through, too many bright and helpful people not to.
  8. PT 328
    PT 328 F1 Rookie
    4,010
    Update: They replaced the two front struts and the problem persisted. They did some additional investigation and are now going to replace the steering rack. Thanks for the insight.
  9. MaleficVTwin
    Jun 5, 2006
    4,312
    Reno NV
    Matt
    When they did the struts did they also do the upper mounts?
  10. F328GTS/GTB
    F328GTS/GTB Formula Junior
    May 3, 2005
    517
    France
    Denis
    Is it hydraulic power assist rack ? electric or manual gear ?
    Do you know the manufacturer of the rack ?
  11. PT 328
    PT 328 F1 Rookie
    4,010
    I will get the details from my neighbor. The rack was ordered yesterday and is to arrive today. He will probably get the car back on Friday so I will take a look at his paperwork and report back. The dealer is sending the info to corporate as this is the first time they have seen this problem.
