Non functioning driving lights switch | FerrariChat
Discussion in '206/246' started by VicJano, Mar 26, 2016.
  1. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Kingston upon Thames
    Chris O'Connor
    Hi,
    Before I break something, has anyone managed to repair the rotating switch on the end of the side/dipped/main lights stalk? The vertical movement switching between the side, dipped and main works fine (I've rigged up temp switched earth to test).
    Does the black end bit come off to expose the switch mechanism and is it repairable.
    Anyone got any pictures?
    Thanks in advance.
    Chris
  2. afer
    afer Karting
    Jun 4, 2009
    122
    Uruguay, S. America
    Alvaro Ferraro
    #2 afer, Mar 26, 2016
  3. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    #3 celestialcoop, Mar 27, 2016
    Hi Chris,
    I successfully repaired that switch; you can, too! There is a very helpful thread that was started by dinodan on 03-23-2009, 12:46 PM. The title is Headlight Switch. Use the Search function to find it.
    You may have to subscribe in order to search (Silver is only £10.61-ish for one year...well worth it.).
    Cheers,
    Coop
  4. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Chris O'Connor
    Thanks Afer and Coop. Much appreciated.
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    We routinely repair this problem by casting a new contact holder onto the stalk & transferring the contacts or installing new contacts as appropriate.
    To contact us just click on my name by this post & select [Send email to Verell].
