Non-LED Compliant Dash Bulbs | FerrariChat
Discussion in '308/328' started by wildcat326, Jun 15, 2017.
  1. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    I was warned in other f-chat tutorials before doing my LED instrument gauge conversion not to make the alternator warning light an LED because it's designed to complete a circuit and may not properly function with a modern LED. Are there any other bulbs for which this applies? I ask because I just replaced all the bulbs but cannot get the 3 lights at the bottom of the tachometer to illuminate (Brights indicator and Brake Failure/Parking Brake). All the wiring looks good, and all the other gauge lights function correctly. I got the Parking Brake light to come on with a normal incandescent, but nada with the Brights.
  2. GordonC
    GordonC F1 Rookie
    4,164
    Calgary, AB, Canada
    Gordon
    The other caution about LED lights is that they are often polarity specific - with an incandescent bulb, it doesn't matter which contact on the bulb connects to positive or negative, but with an LED bulb, it matters. The suggestion is that if an LED bulb doesn't work, reverse the bulb if possible or reverse the wires on the socket to switch the polarity.
  3. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    I read that, too, but I purchased LEDs that work both ways in all the other sockets. I DID try to reverse them; but no luck.
  4. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    This sounds as if the Brights control light doesn't even work with an incandescent. Or do I miss something?
    What's with the other small control lights, like indicators, choke?
    Best
    Martin
  5. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    So far that DOES appear to be accurate. I thought maybe since incandescent worked one bulb over but LED didn't, maybe there was something funky going on that was affecting that cluster area. But I just put everything back together last night, and I'm going to test the wires when I get home today to see if it's an issue of bulb, wire, or whatever deeper internal wiring sending the signal.
    Guess I wanted to make sure that it's okay to use LEDs everywhere else first.
  6. blownfuse
    blownfuse Karting
    Jul 16, 2012
    104
    Campbell, California
    You can have your cake and eat it, too. Try wiring a 100 ohm, 1/4 watt resistor in parallel with the LED. It should simulate the resistance provided by the light bulb, but not draw enough current that the circuit would be overloaded. If that doesn't work, you could try 50 ohms, 20 ohms... but no less.
  7. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    Would this be true of ONLY the alternator warning light, or ALL the five warning lights in the dash (fan, choke, seat belts, hazard)?
  8. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    So, bench tested the tach yesterday afternoon, and the bulbs work fine with current applied. This means either that I have a problem elsewhere in the harness wiring, or that all five instruments need to be fully hooked up in order to properly test. Something else weird is that - after all new bulbs were put into the five warning lights, I can only get the hazard light to come on. Again, either all the instruments need to be hooked up at once for proper testing, or I've got a problem elsewhere. Anyone?
  9. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    Only for the alternator light. It serves for pre-excitation of the alternator, which requires a certain current, which is only created by either the original bulb wattage or a resistor.
    Best
    Martin
