Noob Maintenance Questions | FerrariChat
Discussion in 'Technical Q&A' started by SpeedyOmega, Aug 30, 2019.
  1. SpeedyOmega
    SpeedyOmega Rookie
    Sep 10, 2018
    13
    Dave
    Hi everyone!
    I read this forum a lot and you guys honestly know so much it blows my mind. It's really hard for me to find CORRECT answers on car things because there's so much advice thrown around on the internet-- so I'm hoping you can assist with your expertise.
    1 - what's the best way to keep all those black rubber parts from drying out? (around the windows and doors). I've heard that isn't rubber and so any oil products are actually bad for it. Haven't found a Certified Expert Answer™ yet, tho. I really want to keep that stuff looking fresh!
    2 - my car is new to me and I expect to store it in a garage for extended periods of time between use (especially winter). Should I disconnect the battery leads? Is a battery tender the right move? I'm a bit worried about electricity in my garage (it's very old), but should be fine.
    3 - I get anxiety attacks when I send the car to get detailed. What are the BEST products to use so I can do it myself? (soap, wax, buffer, whatever else you use). Do I need to tape off all the black parts and lights?
    4 - for the winter, I am afraid of mice. How is there not a product that's like a car cover for the bottom that you drive on and tie the corners together? Should I go on Shark Tank, or is there one out there I don't know about?
    Thank you all!!! (I know some of these questions get asked, but I've been through so many forum threads and these are still ones I think I need real authority to weigh in on.)
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,344
    Ian Riddell
  3. SpeedyOmega
    SpeedyOmega Rookie
    Sep 10, 2018
    13
    Dave
    Yes! I had heard about this a long time ago but couldn't remember the name. Okay great that's super helpful to know thank you!
    Qavion likes this.
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
    Q2 - unless you tell us what the car is the answer may vary - newer cars always tender - older cars easier to turn off
  5. SpeedyOmega
    SpeedyOmega Rookie
    Sep 10, 2018
    13
    Dave
    *adjusts fake moustache*
    okay look, hear me out. It's a 1995 Nissan 300ZX. BUT! I have no good user community. It's all teenagers with Autozone bodykits and bolt-on turbos. My car is PERFECT, it is 100% stock, everything works. Last owner had it a few miles from one of the best Z shops in the country so that was easy for him, but I am more isolated. I need to know what the top-of-the-line people (you guys) do. Don't kick me out! I joined because I want to get a 308GTB also, but need to get my knowledge base higher first.
  6. hessank
    hessank Formula 3 Silver Subscribed
    Aug 8, 2005
    1,933
    Canada, Florida
    Fred
    Yo Ω!
    Dude you're worried that electricity but a car with a tank of gasoline is ok?
    Anyways, my mice issue (and it was really bad) was solved with sealing the openings in the garage using the expandable foam you buy in a can and sealing every crack (especially the ones at ground level). Good luck.
  7. BOKE
    BOKE Beaks' Gun Rabbi Rossa Subscribed
    Jul 13, 2009
    33,965
    600 East Fremont Street
    Lucky
    19633500GT likes this.
  8. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,033
  9. vincep99
    vincep99 Formula 3 Owner Silver Subscribed
    Jun 8, 2009
    1,941
  10. Ingenere
    Ingenere F1 Veteran Owner Silver Subscribed
    Dec 11, 2001
    6,453
    On the Limit
    Dino
    So, do you have a Ferrari or not? If this is all about the Datsun....... just leave it outside, it will be fine.
    If you do get a Ferrari, it's just a used car. Do what you would do when buying any car. Due diligence. You said you want a 308, but you are in the 360 section. Talk to the 308 guys. They will give you specifics on that car.
    Cleaning a car. Seriously? Surely you know how to clean a car at this point in your life. Ferraris won't melt.
    The mice thing. I think there is something called a Carcoon that has a floor.
  11. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Mid '90s 300ZX, Pretty Car. Club where I attempt to play golf, member has a pristine red turbo.
    Mice. Based on my vast experience battling mice here in the "country". Nothing beats Victor Original Traps. Bait with peanut butter. Check on a regular schedule.
  12. Mimmo Blue
    Mimmo Blue Formula Junior
    Apr 17, 2018
    324
    Stoney Creek, Ontario, Canada
    Dom
    I use mothballs and bounce dryer sheets in my boat when it goes in a barn in the country for the winter
  13. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,047
    Layered defense would be recommended. Add some baited traps as well.
    Mimmo Blue likes this.
  14. 360+Volt=Prius
    360+Volt=Prius Formula 3 Silver Subscribed
    Sep 1, 2013
    1,762
    Western Mass
    Raimondo
    Took me years of living on the woods in New England to come to the same conclusion. You must be diligent in the fall. Check them every day or 2. I put them all over the garage and around the car. Unless you have empty baited and loaded traps on the floor for a week or 2 you aren’t over the problem yet. And you need to keep checking and rearming traps.
    Also get them early before they reproduce and then the fun really begins.
    Hate mothballs, my daughters tell me makes the car smells like an old person. Dryer sheets and mothball keeps them out of that particular area, but they just go elsewhere where you didn’t put the stuff like under the engine bay covers etc.
    f355spider likes this.
  15. Reid
    Reid Karting
    May 18, 2018
    59
    Vancouver Canada
    Reid Fox
    1/ Mopar makes a product called weatherstrip lubricant, it is a silicon based flourinated lubricant, 1 oz for over $100 if you want something more economical just use a silicon based grease, usually sold as a brake lubricant (brake rubber parts are similar material) just wipe on and wipe off it will absorb into the neoprene moulding and prevent it from sticking to the glass or the body
    2/ Ferrari usually have a battery disconnect under the hood - always disconnect that when storing , a battery minder is a good idea also it only sends a small trickle charge to keep the battery up it will not overheat the battery. A 2 or 10 amp charger could damage the battery after extended periods a dead battery can freeze and that is damaging it could also sulfate which is also damaging, a battery minder prevents all that. An automatic charger will also not damage a battery because it monitors itself ( a good electronic one)
  16. Wade
    Wade Three Time F1 World Champ Owner
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Strangely, the OP hasn't been back since Post # 5 on Aug 31 of this year. And his question was for a car other than a Ferrari.
  17. Reid
    Reid Karting
    May 18, 2018
    59
    Vancouver Canada
    Reid Fox
    Only Ferrari's get mice and dead batteries? These are common issues for any car in storage. Other people actually read these posts like me and you.
    BOKE likes this.
  18. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I was hoping that he would contribute more. At least add a photo of his '95 300zx. I always liked those and they've aged really well.
    Interesting about the weatherstrip lubricant. Makes sense. Years ago I used pure glycerine for the rubber headlight trim (molded surround) on the TR-8 I had. It worked well.
  19. Reid
    Reid Karting
    May 18, 2018
    59
    Vancouver Canada
    Reid Fox
    They were a really nice car. Like he said he was learning how to take care of his future Ferrari, maybe he'll be back when he gets it. I use silicon based lubricants a lot for applications that don't involve oil. It doesn't degrade rubber or neoprene. After reading this thread I noticed an article at one of those natural household solution sites that said to repel mice you cut irish spring soap into chunks and spread them around, apparently they can't stand the smell of it. I wonder if that works well for a car. A lot of Ferrari's already smell like that from the driver.
    BOKE likes this.
  20. eyeman1234
    eyeman1234 Formula 3 Owner
    Dec 25, 2006
    1,881
    Boca Raton, FL
    Dave, you are welcome here- it is safe.
    Besides, we like anybody who likes 308's ... :D
    BOKE likes this.
  21. mwr4440
    mwr4440 Five Time F1 World Champ Rossa Subscribed
    Jun 8, 2007
    57,982
    Bavaria, The 'Other' Germany
    Mark W.R.
  22. Rifledriver
    37,121
  23. Rifledriver
    37,121
    If you have a GTS rub it on the rubber top seal and rubber pins and latches. You can thank me later.
    BOKE and f355spider like this.
  24. mwr4440
    Jun 8, 2007
    57,982
    Mark W.R.
    Next time Im in TX, I plan on 'dropping by.'
  25. Qavion
    Feb 20, 2015
    14,344
    Ian Riddell
    For door/window (rubber) seal preservation.
