Normal Oil Pressure Range 360 Modena | FerrariChat
Discussion in 'Technical Q&A' started by tnferrariowner, Feb 3, 2009.
  1. tnferrariowner
    tnferrariowner Karting
    Jan 30, 2009
    201
    Savannah, GA
    David
    Hello,
    I have just purchased a 360 and my oil pressure seems to operate at around 3/4 of the dial spacing (above the centre reading and half way to the right end of the guage) when driving normally. Is this normal?
    Cheers and thanks in advance.
    David.
  2. Skidkid
    Skidkid F1 Veteran
    9,612
    Campbell, CA
    John Zornes
    It is when the engine is cold. It smooths out as thing warm up.
  3. f355spider
    f355spider F1 World Champ
    18,054
    Depends on what you define as "normally". As mentioned, cold, thick oil will raise the oil pressure (and why you do not rev over 4k rpm until oil temp is over 170 F. The owner's manual should explain where the oil pressure should approximately be based on rpm.
  4. 360RossoFiorano
    360RossoFiorano Formula Junior
    Aug 1, 2006
    622
    Palmetto Bay, FL
    As posted before you should warm up the car....
    On my 360 the pressure after it's at operating temp is anywhere 1/4 - 1/2 and 3/4 at high revs!
  5. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    403
    FL
    David
    I think Ferrari specifies 70-90 psi at 6k rpm at operating temp. Check your manual to verify.
    David
