Not exactly thrilled right now. | FerrariChat
Discussion in '348/355' started by INTMD8, Dec 29, 2009.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    #1 INTMD8, Dec 29, 2009
    Since the roads near my house were dry I decided to take my newly acquired 355 on a short ride down the road and back.
    As I pull into my garage I have coolant pouring out of the car near the right front tire.
    I put it on the lift and the coolant was leaking out of the drain for the heater box, which means either the heater core or coolant hoses connected to the heater core are leaking.
    Not exactly a job I wanted to start the 2nd day after I buy a car. Heater core is removed and I will pressure test it tomorrow to find the source of the leak.
  2. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    That sucks!!! But at least it looks like you can fix it yourself...:)
  3. vetconstruction
    vetconstruction Formula Junior
    Aug 10, 2007
    255
    Northern VA
    Michael A. Whitlow
    +2 That seriously sucks!
  4. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    that's a rough start, but could be alot worse so you still have reason so smile ;)
    Many Ferrari's aren't driven in cold weather so it's not surprising that a coolant leak up front wouldn't be detected until you actually used the heat. Depending on who you purchased from maybe the seller would help out with the cost since it must have been defective when you took possession.
  5. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Look it in this way .... it could have been a lot worse mate !
  6. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,481
    SFPD
    Dirty Harry
    You've been baptized
  7. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    Sorry to hear that James. I can certainly empathize with how you must feel right now. Take it in stride, it's all part of the "charm" of owning a beast like this. You'll probably be telling this story in the years to come with many laughs and fond memories.
    So, hey, what kind of lift is that?
  8. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    Welcome to Ferrari ownership! :D:D
  9. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    I had a heater core leak discovered during the PPI on my 355 last year. It was very expensive to fix due to the labor involved to remove the unit. I guess if you do your own labor the financial costs shouldn't be more than a couple hundred bucks.
  10. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,977
    MD and NE
    Robbie
    Sorry to hear---Hope it is an easy, cheap fix....
  11. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,181
    Australia
    Paolo
    lol
  12. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    That is unfortunate, but luckily you can repair it yourself.
  13. f355jimv
    f355jimv Formula Junior
    Jan 21, 2008
    685
    Southern California
    Jim
    Welcome but remember....it is worth it!
  14. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Thanks Pap, I'm glad my 355 has recieved me with open arms (or is that an open cooling system) :)
    Pressure tested the heater core/hoses today and it was leaking around the lower hose at the heater core. Replaced the factory clamp and it pressure tests fine now. Would have been a lot easier to fix if the ends of the heater core extended past the heater box so the clamps/hoses could be accessed without disassembly (like most cars).
    Rick, the lift is an assymetrical Bend-Pak with low profile arms. Most lifts are 12ft tall but this one was made at 11ft 5in to fit under my ceiling. (clears by about an inch).
  15. sdiamond
    sdiamond Formula Junior
    Mar 25, 2009
    304
    Kildeer
    Steve
    Jim, as others have said, welcome to the world of 'gremlins' and 'why do they do that's. We all seems to have that First week/month crisis but it quickly fades and then it's mostly all big grins and smiles. You have the distinct advantage of knowing your way around mechanicals so I'm sure your transition to ownership will be easier than many, and certainly mine. We look forward to seeing you around town as the weather warms up we all come out of hiding.
  16. BigTex
    79,406
    Houston, Texas
    Bubba
    NOW you have really done it, to start second guessing the Ferrari ENGINEERS!!!! LOL!
    Good point about the location of the clamps...it has to do with where Ferrari breaks the sub assemblies with the vendors..
    You'll find LOTS of these, if you onw the car long term...
    Hats off the you for jumping into it.....be happy!!!
  17. flyguyskt
    flyguyskt Formula Junior
    Sep 22, 2009
    443
    South Dakota
    sean
    #17 flyguyskt, Dec 30, 2009
    is that a chevelle next to the 355? cant tell from tjhis angle4 but she looks clean and has big wheels! perfect for a muscle car!
    and maybe a toyota t100 or older 4runner?
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
  19. ferrari 512 tr
    Nov 16, 2008
    4,181
    Australia
    Paolo
    ring somebody ..
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Well, 3 and a half beers later I got it back together and running. No leaks and everything works.
    I thought I may have messed something up until I realized if you hit the "stop" button for the A/C the heat doesn't work.
    Just need to put the front carpet/trim/weatherstrip/undertray back in and it's done.
    Next thing on the list is addressing the exhaust. It has stock cats and a quicksilver exhaust but sounds much much quieter than I expected.
  21. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    Nice work..:D
  22. Sandy Eggo
    3,636
    Encinitas, CA
    Rick
    Awesome to hear...wish I had skillz like that (car repairs...beer drinking I have down pat).
    BTW, love my Hyperflow cats + Capristo = nice combo.
  23. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    #23 INTMD8, Dec 30, 2009
    Thanks.
    All together now but will need to remove the front trunk carpet section again to recharge the a/c in the spring.
    Took a few pics of the undercarriage while it was on the rack. It's really impressive how they put so much thought into making the underside as clean as possible aerodynamically.
  24. wax
    Jul 20, 2003
    52,481
    SFPD
    Dirty Harry
    Kudos to James for not being INTMD8d
  25. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    Absolutely, good wind tunnel design and first Ferrari with aero undertrays ;) I read in a Forza issue that they couldn't cover the engine on the bottom due to heat dissipation problems, but that was solved on later models.
