Not necessarily for Ferraris but has anyone tried a FIXD obdII reader/analyzer? | FerrariChat
Discussion in 'Technical Q&A' started by staatsof, Aug 13, 2024.
  1. staatsof
    staatsof Nine Time F1 World Champ Silver Subscribed
    Mar 13, 2005
    95,935
    Fuggetaboutitland
    Bob
    https://www.fixd.com/
    Just weak BS or is it somewhat useful?
    I have one of the Chinese BT readers that connects with either my phone or software on my PC and it works well enough for some things but it is a PITA to get to work sometimes. So I wondered if these folks put something together that's worth having for DIY guys?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    What are you looking to do with the dongle ..just read codes ? How many cars would you be using it on ?
    The old AP200.(White and gray one) Is a great choice but is free for life updates for one brand ..
    Buying a good blue tooth dongle and pairing with eobd facile or torque pro is another route
    If you are looking to code or program like say a bmw or a vag group car then that is a whole other discussion
  3. staatsof
    Mar 13, 2005
    95,935
    Fuggetaboutitland
    Bob
    If you look at the advertising for this unit it's meant as a complete solution and not just a dongle for your OBDII socket to retrieve a code. It purports to interpret the code into a description of what's wrong and what need replacing or servicing. As I said I have a reader already and can monitor RPM engine temps etc. No I'm not looking for an extremely capable tool for tuning. I now take my cars to mechanics who are experts on the year/make/model for the car for anything like that. I just wondered if any had used this specific device. I'm not seeking general advice on servicing cars. Thanks.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    I haven't used that but it doesn't seem more than a reader that look up codes on the internet or possible its own database .. I don't think it is anything special based on my reading but o will other chime i who used it.
  5. Rifledriver
    37,075
    Thats like saying a doctor knows your blood pressure is high and that is all that is needed for a diagnosis.
    Sorry. Not buying it.
    I had a lean code on my truck. Of the hundreds of things it could have been was a deteriorated rubber connector hose to my PCV valve. From a lean code and only a lean code there is no way the machine can tell me the rubber hose on my PCV valve had a vacuum leak.
    flash32 likes this.
  6. staatsof
    Mar 13, 2005
    95,935
    Fuggetaboutitland
    Bob
    Oh I expect it to fix the problem too! :rolleyes: This isn't my first rodeo. Last year I had my SC Jag resurrected after an under the SC coolant hose failure. Every hose was replaced, all new intake system gaskets, valve cover gaskets, 3 water water pumps replaced, new plugs, both knock sensors and injectors cleaned. The car runs better than it did when I bought it in 2010 with 12K miles on it. The right technician who knows Jaguars fuel and emissions systems very well took the time and I supplied the money.
    I just thought someone might know if this was a bit better OBDII reader or a sham POS. I didn't come here for a lecture but then you always love to oblige don't you.
  7. staatsof
    Mar 13, 2005
    95,935
    Fuggetaboutitland
    Bob
    That's my impression as well. Thanks.
    flash32 likes this.
  8. Rifledriver
    37,075
    Another easily triggered ***** on ignore.
    RayJohns likes this.
  9. RayJohns
    RayJohns F1 Veteran Silver Subscribed
    May 21, 2006
    7,920
    West Coast
    Ray
    In just looking at their website for a few seconds, it appears you can accomplish basically what they are selling with a $25 OBD2 code reader from Amazon and google for any DTC it reports.
    Retrieving engine trouble codes is really just the tip of the iceberg. It can point you the right direction, but as Brian points out above, it certainly cannot take the place of a skilled mechanic when it comes to tracing down the root cause.
    For more advanced scanning, you'd want something like an Autel scanner, etc. This can provide a big more in-depth information. I personally wouldn't spend your money on the FIXD stuff. Check Amazon for a good quality OBD2 reader if you need codes or as Flash said above, something like eobd facile is well regarded also.
    Ray
    JohnnyS and flash32 like this.
  10. JohnnyS
    JohnnyS F1 World Champ Owner Silver Subscribed
    Oct 19, 2006
    15,277
    Illinois
    Agree with Rifledriver. I had a code for a bad O2 sensor on a 2012 Santa Fe. Replaced it and reset the code. A day later the code pops up again. The real problem was the exhaust manifold got cracked in a rear-end collision several years before, but the manifold actually didn't break for several years. Had to take it to a dealer and they found the problem. I couldn't see the break while on the concrete floor with the bottom of the car 4 inches from my face, but I wasn't really looking for that. I trusted the OBD code reader to diagnose the problem. No more.
  11. RayJohns
    May 21, 2006
    7,920
    West Coast
    Ray
    Yeah I had a Lexus with an O2 sensor error. Issue turned out to be part of the catalytic converter core came loose and went down the exhaust pipe and was cooking the O2 sensor. The previous shop couldn't figure the issue out because they apparently never bothered to look inside the cat nor exhaust pipe. Just blindly replacing things based on DT codes is not how to fix automotive issues.
    Ray
  12. staatsof
    Mar 13, 2005
    95,935
    Fuggetaboutitland
    Bob
    Oh it wasn't easily done but given your enormous ego you probably don't even remember our previous encounters which is fine. You lived up to your reputation once again.
    So ... I criticize your overbearing lecture of a response and you respond by putting me on ignore instead of recognizing the fallacies of your response.
    Bravo :rolleyes:
