430 - Not starting, seeing bad battery symbol? | FerrariChat
430 Not starting, seeing bad battery symbol?
Discussion in '360/430' started by azzurribaggio, Jun 20, 2025.
  1. azzurribaggio
    azzurribaggio Formula Junior
    Image Unavailable, Please Login When I open the door the fuel pump priming doesn't last as long as it normally does (just a guess).
    But I noticed the engine icon stays lit and I also see this symbol.
  2. jerbear27
    jerbear27 Formula Junior
    299
    CT
    Jeremy
    Your battery tender still plugged in?
  3. azzurribaggio
    Yup, I just nominated myself for ****ing idiot of the century.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,897
    Central NJ
    Dominick
    You are probably hearing F1 pump
    If the time has reduced substantial then you may have some issues with the F1 system
    You should time him many mins pump stay off with key in on position
    How many seconds (as accurate as possible) it runs with key on engine off after period it was off
    How many shifts from n to 1 to n do you get
    Mel Spillman likes this.
  5. azzurribaggio
    I had the trickle charger plugged in, car won't start if that's plugged in
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,897
    Central NJ
    Dominick
    Yes ..I realize that but I was addressing your other concern about short pump cycle
    If not a concern ignore my post
    jerbear27 and Qavion like this.
  7. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    280
    So my car, an 05 f430 starts with the tender plugged in. I never realized it wasn’t supposed to. Why do you think that would be? It’s an aftermarket tender if that matters.
  8. colorfull
    colorfull Formula 3
    2,332
    Franklin Park, New Jersey
    John Napoli
    are you using the under dash port? Pretty sure it only works with that
    there is no better feeling than thinking you have a major problem with this car and it turns out it was absolutely nothing! :)
  9. jerbear27
    299
    CT
    Jeremy
    I think it’s only on the 07-09 (?) cars with the under dash port.
    Pete Schweaty likes this.
  10. colorfull
    colorfull Formula 3
    2,332
    John Napoli
    Yeah I’ve never been real clear if it’s the years or if that was an option
  11. Pete Schweaty
    May 21, 2014
    280
    The charger is attached to the battery with a pigtail. It routes out from under the footrest.
  12. Pete Schweaty
    May 21, 2014
    280
    Well that would explain it.
    colorfull likes this.
