Nothing About This Bosch Red Coil Makes Sense | FerrariChat
Discussion in '308/328' started by Dr Tommy Cosgrove, Jun 4, 2007.
  1. Dr Tommy Cosgrove
    36,303
    Birmingham, AL
    Tommy
    In another thread some of us have been discussing the differences between the Bosch Red and Blue Coils and which 308's use what.
    Check out this ad and see if it is accurate in any way for either coil. $29.95 is a good price for a Bosch Red but I don't want to buy a part I can't send back:
    http://www.victoriabritish.com/pdfcatalogs/pdf/SM/0026.pdf
    The voltage, contents, and application don't jive with other Red (or Blue) coil descriptions.
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Dont you have an injected car with dinoplex ignition? That ad says these cannot be used on electronic ignition. These are for points ignition systems only.
  3. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    The red coil required an external balast resistor and the blue coil could be bolted on without. As I remember I used to stock a case of the blue coils as they could be bolted on anything British. I only used the red coils on applications where a resistor was mounted near the coil or if it has resistance wire on the positive feed.
    Dave
  4. dm_n_stuff
    Dec 10, 2003
    43,617
    26.806311,-81.755805
    Dave M.
    #4 dm_n_stuff, Jun 5, 2007
    The ad seems to confirm this.
    What are the spec's on the 308 coil, or is there another thread here chasing it down? What are the differences? I can bug an EE buddy of mine about it.:D
    I've used Victoria British for LBC parts for a while. Good folks.
    www.superformance.co.uk lists a coil for 308's that appears to be magnetti-marelli (sp?) for about $60.
    DM
  5. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    Wow, you're the first person I've ever heard call Long Motor Corp "Good folks". Usually they're described with a bit more explicative. I've used them for a while myself. They're cheap, but their Customer Service is terrible and they've definitely got a "go F' yourself" attitude about customers with problems.
  6. dm_n_stuff
    Dec 10, 2003
    43,617
    Dave M.
    Weird.
    Never had a problem with them. OF course, it's been 3-4 years since I sold the TR6, who knows how they treat people now.
    Never returned anything, either. :D
    DM
  7. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Sorry, I didnt even open the link before I posted. I have used the Blue coil on many applications using Pertronics, Crane, Lucas.... electronic ignition. I am sure the disclaimer came from a complaint that your coil blew up my computer. For many years the Blue coil was the industries best bet for a general replacement. Its been a few years now but Long / Victoria British supplied numerous parts to keep both the TR3 and the Nash Metro alive and well.
    Dave
  8. Dr Tommy Cosgrove
    36,303
    Birmingham, AL
    Tommy
    My confusion is;
    - why is the voltage rated so low for both
    - why is the blue voltage rated higher than the red (they told me it was on the phone)
    - oil filled (it has been said here it is actually filled with epoxy)
    - don't use with electronic ignitions (either one? I thought the red was made for them)
    I don't know. All of this is just completely upside down opposite from how the experts here describe them.
  9. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,790
    Atlanta
    John!
    Ok. I just got off the phone with Don who is a tech correspondant with Bosch. In order to reach them, one must call their number, leave a message with the attendant, and then the tech calls you back. Quite the process, but makes sense so they are not killed with calls. Anyway.
    Don stated that the red coil primary resistance is about 1.2 ohms, and the secondary resistance is about 5.5 ohm. The windings in the red coil is about 200:1. The red and blue coils are 'resin' filled, not oil or epoxy filled. Don stated that the resin they use has tested to be much better than even epoxy when it came to vibration and mountability. Don could not tell me an exact power output from the coils, but he did say that the coil industry severely 'pads' their numbers to sell coils. So a 45k volt coil that other companies claim is more like 35k-40k. Don said that the red coil is better than any other performance coil out because the resin they use inside is much better, and the power output is 'at least' what any others are putting out. A stock coil puts out about 17k volts, and the blue coil is more than twice as strong as a stock coil. He further advised that the red coil is stronger than the blue coil by around a 25-30% margin.
    Hope this clears everything up. If anyone else wants to call to speak with a tech, call 888-715-3616, leave your name with the attendant and what you want to talk about, and you will be called by a tech shortly.
  10. thecarreaper
    thecarreaper F1 World Champ
    17,998
    Savannah
    Crane Cams PS60 coils worked great in my 308s with carbs. low price too.
  11. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Would they work on an injected '80?
  12. Dr Tommy Cosgrove
    36,303
    Birmingham, AL
    Tommy
    Thanks for the tech #, this has been a bit of a search. I have been on the phone with a company here in town that has been selling foreign parts for about 30 years. Evidentally all Red coils are not equal. The biggest problem I have been having is cross-referencing it. NO one has a c.r. # for a Ferrari 308 with Bosch. That has been the big problem finding one.
    I did ask for an Alfa Romeo Spider 1985. I thought that would be as close as anything. For that car there are 4 numbers:
    00051 that was superceeded by 00103 later. Those are the "short" numbers that corrospond with Bosch 0221122026 and later 0221122025 respectively (the "long" numbers for the same part - whatever that means). He could not tell me what the output voltage or anything was. His book doesn't say.
    I'll talk to the tech support and give them what I have got so far.
    I really want the Bosch. I could make my life so much simpler by picking up the phone and ordering the MSD Blaster but I think long term Bosch is the way to go.
    Anyone know the output on the stock coils?
  13. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    A stock coil puts out about 17k volts,...
    Don't know if that was mean't to describe 308 coils.
  14. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    I used Red coils in my 308. Double Perlux installed in one distributor, Rewired so the ballast resistors are between the key and the positive side of the coil. (stock Ferrari they are between the points and the coil which is weird). The ballast resistors are bypassed with the key in the start position.
    The "rewiring" was simple, because it actually only involved juggling terminals around.
    Jay
  15. BigTex
    79,338
    Houston, Texas
    Bubba
    Ricambi has the correct ones, but I bolted on the MSD epoxy ones that Franklin Parker uses on his Boxer......
  16. Ferraripilot
    May 10, 2006
    17,790
    Atlanta
    John!
    17k volts would not surprise me for the Marelli coils, but my above statement was not directly for Marelli coils, just 'stock' coils in general.
    Bosch changed their part numbers for the red and blue coils when manufacturing plants/techniques changed. They started in Germany, then were made in Brazil (been in Brazil for a long time now). The red coil was even silver with a red label for a little while. They all have different part numbers, but you can rest assured there is only one 12v red coil, and one 12v blue coil.
  17. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    When the starter is cranking, the battery voltage may get down to 8 or so volts. To insure adequate spark in tough winter mornings, coils may be designed for an 8v primary with the excess dropped by a ballast resistor. During the crank event, full battery voltage is applied to the coil, bypassing the resistor. Returning the key to 'run' places the resistor back in the circuit to drop the battery voltage, now up to as much as 14v, so that the coil is back in operating range.
    I have no idea who and how many run this scheme but have run into it often. By aware that use of electronics rather than breaker points introduces a whole new set of criteria and the general rule is matching components as the circuitry has be specifically designed to work with a particular coil as it does more than just ground the coil for spark but also modifies the duration of the coil grounding to build a hotter spark under certain conditions. And some even regulate the input voltage to the coil primary. Match, don't mix. Better yet if it ain't broke...
  18. thecarreaper
    17,998
    Savannah
    Cranes tech guys were super helpful, they knew what they were doing and were excited to help me with my dual XR3000 install on my 77 gtb ( i freaking detest points). i cannot tell you they will work on an injected car, but i would suggest calling them and asking. the xr3000 thread i posted should have their tech number, or just google them.
  19. Dr Tommy Cosgrove
    36,303
    Birmingham, AL
    Tommy
    Just got off the phone with Mike from Bosch. VERY helpful Very nice. I learned a lot. For one VictoriaBritish's ad is not accurate. Only the BLUE is for cars without electronic ignition and they are not filled with oil as the ad states.
    Besides that, the "standard" Bosch Red coil anywhere is 26,000 volts (NOT 50,000) and is resin filled. There is NO Cross-reference number for the Ferrari 308, but part # 00013 is the one that should work. The "long" number is 0221119030.
    For anyone ordering one from someone that asks for the car it's going in, tell them a 1974 BMW 2002 tii 2.0L. There is your cross-reference.
    All of this is just what Bosch told me.
  20. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    My 77 has a Pertronix conversion with both pick ups in 1 dizzy. I rewired my Bosch "Blue" coils so that they get 12V on both the start and run position on the ign. key. I have had this setup since 2000 and have never touched it. I run black extenders and 7MM carbon core wires which I made up and NGK 5 ES plugs. Timing is set at 7* BTDC and it runs like a raped ape. Just my 2 cents here.
  21. Ferraripilot
    May 10, 2006
    17,790
    Atlanta
    John!
    WOW. That is amazing. I just spoke with Don at Bosch this morning at the same phone number, and was provided totally different output numbers. That is kind of flabbergasting.
  22. Dr Tommy Cosgrove
    36,303
    Birmingham, AL
    Tommy
    maybe not.
    In your earlier post you said Don couldn't give you any output numbers. This guy Mike answered my questions almost beore I could finish asking. He sounded like he really knew his stuff.
    Mike also told me the Red was the top of the line for power, below that was the Blue then the Black. I don't remember the details with those.
    Bottom line is this, the Red is the one for the 80-up 308's. It has about 10K more output than the stock units. As for a cross reference car - say you have the BMW as I stated above since that is how most dealers list them - by car type - NOT by a number. Don't even try to say a Ferrari because even Bosch has no info for our cars on record. That number is different for everyone. For example VictoriaBristish lists it as 10-421 but that is in no way a Bosch Red coil # from the factory.
    For the internet age and with all my contacts, this was the hardest part I have had to track down and confirm. Unbelievable. I mean I can understand if I were trying to source a rear view mirror switch for my QV but not a simple coil for crying out loud. I got a different coil story from practically everyone I spoke with and since there was no cross-ref # for my car I had a helluva time coming up with a good-guess substitute car. The absolute LAST car I would have thought of would have been a 74 BMW - 74 ANYTHING for that matter.
    Anyway I ordered a couple from Victoria British this afternoon. These new coils, maybe a couple new crank sensors and all new cap and rotors should put me back on the road in no time.
  23. Ferraripilot
    May 10, 2006
    17,790
    Atlanta
    John!
    Let us know how they worked out. I am glad you got some straight answers and am even more glad the community has some truth on the subject.
    I was reading up on coils a bit this afternoon to satiate the bug. I went to various webistes, and then found myself on MSD's website. From what I read, their blaster coil outputs are rated at 45k volts, BUT that voltage is while using a MSD 6A or the like box. In their item description they are very clear below the actually description in stating that voltage figures were obtained while using MSD 6A. Any coil getting charged with 480-550 volts constantly is going to put out at least twice its normal capacity. So what on Earth are those coils putting out with a plane jane points set-up I wonder.
