News
Novitec 360
Discussion in '360/430' started by CRG125, Aug 30, 2006.
  1. CRG125
    CRG125 Formula 3
    Feb 7, 2005
    2,393
    Los Angeles, Ca
    Vivek
    Wanted to know about the Novitec 360. Is the motor from Novitec a modified 360 motor or is it something completely different?
  3. egyptfolyf
    egyptfolyf Rookie
    Mar 29, 2006
    19
    Novitec has a Bi Compressor Conversion kit. Its a twin supercharger system with an independent oil system , modified and insulated air induction system; water cooled intercoolers with water pumps and additional radiator, re-inforced drive belts with dynamic tensioners; additional fuel injectors; reprogrammed Motronics and 2 Novitec Tectronic units; carbon air filter housing, high flow cats and exhaust manifolds.... All this leads to 560hp, 415 ft-lbs of torque and a 3.8sec 0-60mph
    I saw it on the CEC website
  4. frayed
    frayed Karting
    Aug 6, 2006
    195
    Are you guys familiar with the compressors Novitech uses? They are Rotrex. Known from other tuning communities to be substrandard. Poor adiabatic efficiencies and used generally for low cost applications or for tight packaging.
    They are also centrifugal blower units; the type that not a single OEM puts on their cars from the factory. To my knowledge all supercharged cars from the factory are positive displacement units (not centrifugal), generally of the twin screw variety like that on the Ford GT.
    Anyway, caveat emptor.
