Novitec lowering springs for Pista? | FerrariChat
Discussion in '458 Italia/488/F8' started by kevin1244, Aug 21, 2019.
  1. kevin1244
    kevin1244 Formula Junior
    Mar 7, 2008
    308
    Northern California
    KAA
    Anyone thinking of installing Novitec lowering springs on their cars? I am thinking of installing the springs and also add spacers to the OEM wheels.
    Novitec customer service is horrible though. They never respond to my messages.
  2. ScuderiaCarParts
    157
    London, UK
    Scuderia Car Parts
    Check your PM's! :)
  3. Autolove
    Autolove Karting
    Jun 8, 2012
    243
    S.A. TX.
    Ivan
    Can you send me pricing too! Thanks
  4. VividRacing
    VividRacing F1 Rookie
    Aug 23, 2005
    2,986
    Gilbert, AZ
    PM's sent!
    -James
  5. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    What is the minimum and maximum lowering of the Novi Pista/Pista Spider springs?
  6. AK488
    AK488 Rookie
    Nov 12, 2017
    5
    Andy Ko
    Are the spacers for the Pista the same as the GTB?
  7. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    The Novi spacers are universal for the 458, 488, 599, 812, FF, Lusso, F12, Porto/Cali and Pista.
    As a matter of personal taste and preference, have you co sidered the Hill Engineering spacers? They are some of, if not the nicest spacers I've ever seen. The quality on those are top shelf, and spacers are a pretty big deal in terms of safety.
  8. AK488
    AK488 Rookie
    Nov 12, 2017
    5
    Andy Ko
    Hey, thanks for your recommendation. The reason I asked, is because I am currently using the Novitec Spacers on my 488, and my Pista will be arriving by the end of the year. If they are universal, I will transfer them to from the 488 to the Pista.
  9. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    No prob:)
    Should look the same. Only think that can make a difference is if the Pista has different wheel offsets. But from what I understand, it has the same offset as the 488. Put them on and see how you like it. They will fit. PCD, center bore, bolt size etc. it's all the same. Double check that the bolts you currently use with the spacers are also long enough to be used on the Pista wheels in case the rim flange thickness is different on the Pista wheels. I'm 99.99% sure it's not, just check it so that you're certain that you have proper bolt engagement in the hub.
    AK488 likes this.
