novitec wheels nf3 | FerrariChat
novitec wheels nf3
Discussion in '360/430' started by rolltheyo, Jan 21, 2009.
  1. rolltheyo
    rolltheyo Rookie
    Dec 24, 2008
    23
    Thinking about getting the novitec nf3 for my 430 but have a couple questions.
    Should I go with 20s in the rear and 19s up front or 20s all the way around?
    How much do you think the lower profile tire will affect the ride?
    The car is charcoal grey flat black or silver wheels?
  2. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    The NF3 wheels are only 20" all the way around. The NF2's are 19" and 20". I would go with black centers with body colored lips.:)
  3. cat1pro
    cat1pro Formula Junior
    Jan 3, 2009
    292
    Deerfield Beach, Fl
    Alain
    when you change wheel and tire sizes does it require any changes to the ecu?
  4. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    No. As the wheel weight goes up your tire sidewall goes down so you have the same overall diameter. If the diameter changes then you have issues.
  5. rolltheyo
    rolltheyo Rookie
    Dec 24, 2008
    23
    Do you think the ride will suffer alot due to the lower profile tire.
  6. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    I drive a Lotus everyday so I am a bad judge but I don't think it will be that bad.
