Nuvu 94 octane gas? | FerrariChat
Nuvu 94 octane gas?
Discussion in '348/355' started by Carmellini, Jul 13, 2025.
  1. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    964
    New station in my area called Nuvu features 94 octane gas for a lot less than competitors
    but contains 30% bioethanol. Not sure if this is good for older cars?
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    30% ????. I would avoid even 5%. I think alcohol can cause swelling of rubber (unless alcohol resistant) and it also absorbs moisture = seized fuel pump(s), internal corrosion of fuel lines etc.
    Used in alcohol proof modern cars which are used daily is another matter.
    Carmellini likes this.
  3. Carmellini
    Jul 16, 2019
    964
    Didn't think it could be a good thing, but 94 octane and price was attractive.
    Recreational fuel is available and does not have any ethanol but octane is only 90.
    Better to use low octane (90) and no ethanol, or higher octane (90) with 10% ethanol?
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,757
    Lake Villa IL
    May result in lean codes and running lean at wide open throttle as gasoline stoich value is about 14.7. E10 is 14.1 and E30 is 12.9
  5. Carmellini
    Jul 16, 2019
    964
    Did not say anything about ethanol % at the pump.
    Only put in a few gallons.
    Anything I can add to attempt to neutralize?
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,757
    Lake Villa IL
    #6 INTMD8, Jul 13, 2025
    You said it contains 30% bioethanol, no?
    Edit- Not sure what you meant on the pump comment but it's nothing to worry about. Just top it off with a fuel with less ethanol.
  7. m.stojanovic
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    This gives you a good reason to drive the car every day and use up the ethanol quickly. It won't do any harm in a short term, just don't leave it in the system over a longer period of time.
  8. ChoonHound
    ChoonHound Formula 3
    2,219
    Saint Michaels, MD
    Lucas
    Why would you try to save 2 pesos on gas in your classic Ferrari?
    Ob917 and Carmellini like this.
  9. Carmellini
    Jul 16, 2019
    964
    LOL....that wasn't the goal. It was 4 AM and this was the only station open, Used to be a Chevron. The attraction was 94 octane with
    no mention of ethanol amount, so I assumed it was the usual less than 10%. Only after an internet search did I realize......
    ChoonHound likes this.
  10. Carmellini
    Jul 16, 2019
    964
    FWIW: A search on Pure Gas lists all stations nationwide
    that sell ethanol free gas has a station less than 5 miles away with 93 octane. E0 gas.
    https://www.pure-gas.org/
