NYTS Gas Price-Check | FerrariChat
Discussion in 'New York Tri-State' started by ghost, Aug 7, 2006.
  1. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    What are people paying to fill up their exotics?
    Most recently (this weekend), $3.09 for Regular.
  2. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,854
    Long Island, NY
    Sam
    You use regular, not super? I pay 2.91 -2.97 in NJ where I work.
  3. revsto9k
    revsto9k Formula Junior
    Aug 3, 2006
    402
    Clifton, New Jersey
    Anuj
    $3.19.9 for 93 @ BP this past Saturday (August 5th) - North NJ.
  4. ClydeM
    ClydeM F1 World Champ
    11,875
    Wayne, NJ
    Clyde E. McMurdy
    2.95 Hess Regular in Jersey this morning.
    I'll ride by the station on the way home & see what it is. :'(
  5. jdogg
    jdogg Karting
    May 16, 2006
    171
    JD
    3.09 on Friday for Regular.
  6. 993 guy
    993 guy F1 Rookie
    May 21, 2004
    3,066
    Bergen County NJ
    Eric D
    Who the hell uses regular here?
    I pay between $3.19 - $3.25 at the stations by me.
    That is about to change though with BP taking the largest US oil field offline for repairs. :(
  7. ghost
    Dec 10, 2003
    10,046
    Singapore
    I use Regular. Thought it was all marketing hype. Shivam's now telling me I've got it all wrong, and the V10 actually makes use of the Premium fuel. - :eek:
  8. idloveaguinness
    idloveaguinness Formula Junior
    Nov 3, 2003
    684
    LI NY
    Kevin Landry
    That's a bargain compared to LI...and you don't even have to (CAN'T) pump it yourself.
  9. Ciao Bello 348
    Ciao Bello 348 Formula 3
    Oct 3, 2005
    1,844
    The Garden State, US
    John C
    Someone didnt read their owners manual.
    I still got a picture of the FERRARI and lamborghini gas caps as Vik filled with 87 octane.
    Yes, im biased (for now)
    About the gas prices.. I havent driven mine since the poker run. A quick jaunt to Classic Coach for oil service. Dats it. Before that, i remember paying close to $50 from empty. Those who know me know im ALWAYS on empty for some reason.
  10. Parikh1234
    Parikh1234 F1 Rookie
    4,726
    Little Ferry, NJ USA
    Shivam Parikh
    I found a great writeup of this issue, but I lost it. I will try and find it again.
  11. Parikh1234
    4,726
    Shivam Parikh
    http://www.faqs.org/faqs/autos/gasoline-faq/part3/
    Most importantly:
    6.13 Can higher octane fuels give me more power?
    On modern engines with sophisticated engine management systems, the engine
    can operate efficiently on fuels of a wider range of octane rating, but there
    remains an optimum octane for the engine under specific driving conditions.
    Older cars without such systems are more restricted in their choice of fuel,
    as the engine can not automatically adjust to accommodate lower octane fuel.
    Because knock is so destructive, owners of older cars must use fuel that will
    not knock under the most demanding conditions they encounter, and must
    continue to use that fuel, even if they only occasionally require the octane.
    If you are already using the proper octane fuel, you will not obtain more
    power from higher octane fuels. The engine will be already operating at
    optimum settings, and a higher octane should have no effect on the management
    system. Your driveability and fuel economy will remain the same. The higher
    octane fuel costs more, so you are just throwing money away. If you are
    already using a fuel with an octane rating slightly below the optimum, then
    using a higher octane fuel will cause the engine management system to move to
    the optimum settings, possibly resulting in both increased power and improved
    fuel economy. You may be able to change octanes between seasons ( reduce
    octane in winter ) to obtain the most cost-effective fuel without loss of
    driveability.
    Once you have identified the fuel that keeps the engine at optimum settings,
    there is no advantage in moving to an even higher octane fuel. The
    manufacturer's recommendation is conservative, so you may be able to
    carefully reduce the fuel octane. The penalty for getting it badly wrong,
    and not realising that you have, could be expensive engine damage.
    6.14 Does low octane fuel increase engine wear?
    Not if you are meeting the octane requirement of the engine. If you are not
    meeting the octane requirement, the engine will rapidly suffer major damage
    due to knock. You must not use fuels that produce sustained audible knock,
    as engine damage will occur. If the octane is just sufficient, the engine
    management system will move settings to a less optimal position, and the
    only major penalty will be increased costs due to poor fuel economy.
    Whenever possible, engines should be operated at the optimum position for
    long-term reliability. Engine wear is mainly related to design,
    manufacturing, maintenance and lubrication factors. Once the octane and
    run-on requirements of the engine are satisfied, increased octane will have
    no beneficial effect on the engine. Run-on is the tendency of an engine to
    continue running after the ignition has been switched off, and is discussed
    in more detail in Section 8.2. The quality of gasoline, and the additive
    package used, would be more likely to affect the rate of engine wear, rather
    than the octane rating.
    6.16 What happens if I use the wrong octane fuel?
    If you use a fuel with an octane rating below the requirement of the engine,
    the management system may move the engine settings into an area of less
    efficient combustion, resulting in reduced power and reduced fuel economy.
    You will be losing both money and driveability. If you use a fuel with an
    octane rating higher than what the engine can use, you are just wasting
    money by paying for octane that you can not utilise. The additive packages
    are matched to the engines using the fuel, for example intake valve deposit
    control additive concentrations may be increased in the premium octane grade.
    If your vehicle does not have a knock sensor, then using a fuel with an
    octane rating significantly below the octane requirement of the engine means
    that the little men with hammers will gleefully pummel your engine to pieces.
    You should initially be guided by the vehicle manufacturer's recommendations,
    however you can experiment, as the variations in vehicle tolerances can
    mean that Octane Number Requirement for a given vehicle model can range
    over 6 Octane Numbers. Caution should be used, and remember to compensate
    if the conditions change, such as carrying more people or driving in
    different ambient conditions. You can often reduce the octane of the fuel
    you use in winter because the temperature decrease and possible humidity
    changes may significantly reduce the octane requirement of the engine.
    Use the octane that provides cost-effective driveability and performance,
    using anything more is waste of money, and anything less could result in
    an unscheduled, expensive visit to your mechanic.
    I am pretty sure lambo as well as many other high end cars take advantage of higher fuel grades. I used to think it was a gimic until I saw dyno plots:)
  12. Ciao Bello 348
    Oct 3, 2005
    1,844
    John C
    Not to drag this out, but I know for a fact being an X-Owner of a Jag S-Type 4.0, that that engine (in the owner's manual) stated it "REQUIRED" an octane of 91 or higher. NOTHING less was clearly spelled out.
    Since Ford owns Jag, I know it to be true in a few of the Lincoln models (obviously the LS as its the same car as the S-Type).
    Think the Corvette manual might have the same. Been a long time since I read one.
  13. BlackRX7Turbo
    BlackRX7Turbo Karting
    Sep 18, 2004
    225
    Northern Jersey
    Aaron
    $2.919 (Regular) at Exxon.... of Rt 23 in Newfoundland....
  14. Ferrarispeed28
    Ferrarispeed28 Formula 3
    Mar 11, 2004
    1,661
    NY/AZ
    Evan
    3.28 for 87 Octane in Scarsdale, NY
  15. revsto9k
    Aug 3, 2006
    402
    Clifton, New Jersey
    Anuj
    Exactly. I cannot tell if you guys are showing sarcasm or not but I would figure sophisticated engines such as yours would require a higher grade fuel. My 11.5:1 motor requires 91+ (stated in the manual and gas cap area).
  16. vteqe
    vteqe Formula Junior
    Mar 5, 2005
    664
    long Island, NY
    Sandy
    F 308QVs require RON 91. Premium on LI ranges now from the high $3.40s to $3.60. Last week when I was in Tennessee premium was $3.09. Very little upper level imported cars there. I am guessing F & Ls are quite rare out side the larger cities.
  17. rpps
    rpps Formula 3
    Aug 20, 2005
    1,828
    Bergen County, NJ
    Richard
    8/7
    93 octane - $3.25
  18. Parikh1234
    4,726
    Shivam Parikh
    I know of a couple of cases where car companies have voided warranties because of excess buildup due to a lower grade gasoline.
  19. BlackRX7Turbo
    Sep 18, 2004
    225
    Northern Jersey
    Aaron
    Super at the Lukoil in Oak Ridge - $3.199...
    What was interesting once is my brother in law told me about a guy on a chat board he frequents where someone with a 911 turbo complained about how lousy his car ran -- bad acceleration, ran rough, etc...
    the guy kept filling his car with 86 octane gas, once in a while filling with 87, when 86 wasn't available....
  20. racerx3317
    racerx3317 F1 Veteran
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    3.45 for premium in queens at a Gulf station right off the LIE around exit 25. Pretty cheap, I usually pay over 3.50 a gallon for premium
  21. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    It says 91 is strongly recomended though the car will run on the cheap stuff albiet with reduced power.
  22. ClydeM
    11,875
    Wayne, NJ
    Clyde E. McMurdy
    My '83 308Qv (no so-fist-i-kat-d engine management system on-board) can use regular. I've gone years on hi-test and years on regular with no significant gain or loss (measured in MPG at every fill) using regular, hi-test, or supreme.
    I believe the salient pieces are;
    1) I did my measurements on the East Coast
    2) The gas stations I used were hi volume resellers (no stale gas)
    3) addititives probably do play some role in the engine besides marketing so buy a bottle of that chevron Techron occationally.
    4) The engine needs to be "tuned" or adjusted for the octane being used.
    But mine is an '83. It'd be really nice to grab a hold of some engine design engineers and see just where the "Hi-Test" recommendation came from. The Oil companies maybe???
  23. JStone414
    JStone414 Formula 3
    Sep 23, 2004
    1,163
    Gotham
    Roman Sionis
    you've got to be kidding.....
  24. DodgeViper01
    DodgeViper01 F1 Veteran
    Oct 1, 2003
    6,867
    To save a few bucks? If you really look at it, the difference is less that $5.00 to put premium versus regular and is most cases it is a lot cheaper.
    Example: Regular $3.00 & Premium $3.25 and you have a 20 gallon tank, the difference is only $2.50!
    I figure if we can own these, we should be able to afford gas, especially since most of these cars are driven only on weekends or nice days.
  25. ghost
    Dec 10, 2003
    10,046
    Singapore
    You're right Keith. I use Regular so I can save myself the 5 bucks a month from my twice-monthly gas trips - :rolleyes:
    I switched to Regular because there seemed to be no noticeable difference between Premium and Regular. I took away the following from the post that Shivam linked to:
    FYI, there is no sustained audible knock.
    To me, the only interesting part of that article is the following:
    So theoretically the question is, by using 87 / 89 grade gas, am I running at an octane that is "just sufficient," or one that meets the "optimal" requirements.
    Haven't had a chance to check the owner's manual to see if there is a minimum octane recommendation - will do so this evening.
