O-Ring for Engine Oil Strainer | FerrariChat
Discussion in '360/430' started by -JPD-, Apr 1, 2024.
  1. -JPD-
    -JPD- Rookie
    Jan 8, 2024
    4
    John DaCruz
    Image Unavailable, Please Login Any insight on where I can obtain an O-Ring for the engine oil strainer in the picture for my 360? Also, does this strainer need to be replaced or just cleaned? Than you in advance for your input.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,949
    Central NJ
    Dominick
    If screen doesn't have holes in it .just clean gently
    177549 & 177550 ..o rings you need
    Search for them on Google..all the usually places have them but unless you are buying other stuff the shipping may kill you in terms of cost ..price at a local dealer
    -JPD- likes this.
  3. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    908
    S La
    If the Orings are OK, no leaks before, lube and re-use them.
    360+Volt=Prius likes this.
