O2 Sensor Codes - 0153, 0159, 0133, 1039 | Page 2 | FerrariChat
Discussion in '348/355' started by RotarySwingGolf, Mar 8, 2012.
  1. fatbillybob
    Aug 10, 2002
    29,266
    socal
    I want to race an F1 in a bad way. When racing I'm not into nostalgia. But I also want to finish races. So for now its 3 pedals or go to the dark side. I figure I got one more race car where this old hillbilly can be competative. I want to do at least 1 pro race before I degenerate to casual trackdays.
  2. RotarySwingGolf
    RotarySwingGolf Formula Junior
    Dec 24, 2011
    490
    Florida and Idaho
    Ok guys, put the OEM upstream O2 sensors in, new codes now, but fewer! First is a pending 1115. I think this is the sensor heater, although I don't know exactly what that is or where it is, either way, this code was not here before, so I'm guessing that this is actually the O2 sensor itself is no good? I also have 0134 which says no activity of Bank 1 Sensor 1. Since this is the same bank that is tripping 1115, I'm leaning towards that O2 sensor being dead. Does this make sense? If so, does anyone have the correct part number? I pulled the number for the one I ordered off this site and then later found out there was some discrepancy between part numbers. Lastly, is bank 1 the driver's side?
  3. RotarySwingGolf
    Dec 24, 2011
    490
    Florida and Idaho
  4. WATSON
    23,926
    WI
    I assume that sequence is correct. I did a lot of research before installing mine and found that the installation sequence has been listed backwards in some places.
    Since installing the Bosch 03819 as the pre cat sensor, I have over 400 miles on the car without any codes (including pending codes).
    The rest of your questions are in better hands than mine....I am just reading and learning.
  5. RotarySwingGolf
    Dec 24, 2011
    490
    Florida and Idaho
    Hi Watson, what do you mean by installation sequence?
  6. WATSON
    23,926
    WI
    Location of the O2 sensors.
  7. LAracer
    LAracer Karting
    Jan 4, 2008
    131
    Northern NM
    Phil
    RotarySwingGolf: did you ever resolve this issue? I have exactly the same codes.
