O2 sensor location on 84 QV | FerrariChat
Discussion in '308/328' started by olehholy, Sep 24, 2009.
  1. olehholy
    olehholy Karting
    Nov 12, 2003
    122
    NJ
    Oleh Holynskyj
    #1 olehholy, Sep 24, 2009
    Hello:
    I am trying to locate the O2 sensor in my 1984 US 308QV. I assumed it was connected to the catalyctic but all I see is what looks like a 19mm bolt in a test bung. See Pic. Is this where the O2 sensor "used" to be or am I looking in the wrong place and this is a test port.
    Thx,
    Oleh
  2. Dr Tommy Cosgrove
    36,451
    Birmingham, AL
    Tommy
    That looks like it.
    Your car will run much better without it. If you do want a new one, it is the O2 from a 99 Saab 16V Turbo. Buy the Bosch unit for that car. Much cheaper.
  3. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    That is it, looks like someone removed it (obviously) LOL , anyway you may want to run down the rest of the Lamda system and see what is working and what is not.
    There should also be another smaller bung on the other end of the cat for your thermocoupler.
    Wade
    www.sportclassiccomp.com
    www.308qvregister.com
  4. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Actually what you are seeing is the pressure relief plug in case the cat get clogged. You are almost there, stay on that side and try to reach your hand on top of the cat and you will feel the wires with O2 sensor. It may even have a metal protective shield like mine that I just replaced. I have a 1985 US 308QV
  5. Steve Magnusson
    26,846
    #5 Steve Magnusson, Sep 24, 2009
    I believe that is the "inspection port". Have a look on the other side of the cat at that same (inlet) end -- there should be a larger port for the O2 sensor:
  6. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    #6 308nut, Sep 24, 2009
    you are right Steve, checked out a few cats I have laying around and two of the 3 have inspection (pressure relief ports) and one does not. Strange why one would and one would not.
    sorry to confuse
    Wade
  7. Steve Magnusson
    26,846
    That would be rather strange if they are all the "official" 308QV/328/TR cat PN 121385, but not all cats have such an inlet inspection port -- so, if the cat you mention without it is a different PN or manufacturer, that's maybe not unusual.
    On 121385, it is a just solid threaded plug so it really wouldn't have any "pressure relief" function -- just a place where you can look in to see if the catalyst matrix is physically OK or not, or where you can tap off a sample of "untreated" exhaust gas.
  8. olehholy
    olehholy Karting
    Nov 12, 2003
    122
    NJ
    Oleh Holynskyj
    Thanks guys,
    When you had to replace yours, what was the best access, through the pass-side the wheel-well ? Did you need one of the O2 sensor special sockets or just a regular deep ?
    Oleh
  9. Dr Tommy Cosgrove
    36,451
    Birmingham, AL
    Tommy
    I cannot remember if I took off the rear wheel or not. I do know that it was easy to get to and I did not need a special tool.
    This is a very easy DIY. Remember the Saab O2 sensor. Even the hookup is exactly the same.
  10. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    Guys, is there just 1 cat on the US QVs? How does it run with a test pipe in there instead? Any difference?
    Thanks.
  11. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    I replaced mine about years ago with a test pipe, it runs better is a bit louder but have gone through 2 O2 sensors since.
    Wade
  12. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Bought mine at a local parts store, original Bosch #13957, perfect fit including wires, no splicing necessary, $75. You don't have to remove wheel, just lay on your back if you can and slide under the car and reach in with open end wrench. Comes off like a spark plug with wire intact. Very easy
  13. Dr Tommy Cosgrove
    36,451
    Birmingham, AL
    Tommy
    The 83 QV's had two cats. 84 and 85 had one.
    It runs fine with a test pipe and sounds pretty good too. It just is a eye and nose burning experience, more or less, depending on the tune. The Hyperflow cat is as good as a test pipe without the smell.
  14. olehholy
    olehholy Karting
    Nov 12, 2003
    122
    NJ
    Oleh Holynskyj
    jlc308,
    The replacement does not seem to have the metal shield, did you re-use the old one ? The shield does not interfere with getting a socket or wrench on the thing ?
    Oleh
  15. Steve Magnusson
    26,846
    The metal shield is a separte part that has spring clips that go around the O2 sensor body so it can be removed before removing the O2 sensor.
  16. olehholy
    olehholy Karting
    Nov 12, 2003
    122
    NJ
    Oleh Holynskyj
    Thx, Steve,
    Do I pull straight up to pop it off or does the shield slide off to the side.
    Oleh
  17. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    Maybe this will be relevant; maybe not. I have a 1988 1/2 Mondial 3.2 and I just installed a Stebro w/ cat bypass (test pipe). The difference is amazing. Really; it feels like another 40 HP. I have been told the change shouldn't feel that dramatic, but it does. Maybe my cat was clogging up, but the difference is astounding.
