OB2 Scanner for F355 | FerrariChat
Discussion in '348/355' started by Ebarela, Jul 9, 2024 at 8:50 PM.
  1. Ebarela
    Ebarela Rookie
    Jun 18, 2022
    13
    Las Vegas
    Ernest Barela
    Hello,
    Looking for recommendations on what OB2 Scanner works best on F355 (1999). Thank you in advance.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,910
    Central NJ
    Dominick
    Not knowing what you want the scanner to do for you ? Only read codes ?
    I think the AP200 ( old version - white) is a great scan tool for ferrari - especially for 50 dollars
    Ebarela likes this.
  3. Qavion
    Qavion F1 World Champ
    12,025
    Ian Riddell
    Don't expect too much from cheap scanners (<$10K). Airbag, suspension, hvac, abs, etc, data is not fed to the OBD2 port. Some recommend bluetooth devices with smartphone apps which produce more useful data (in graphical form).
    Cheap scanners may not properly decode non-generic (POxxxx) codes and may point to devices not even fitted to the F355.
    Ebarela and flash32 like this.
  4. Ebarela
    Ebarela Rookie
    Jun 18, 2022
    13
    Las Vegas
    Ernest Barela
    Thank you. I keep getting a check engine light and when I take it to the Ferrari dealer they don’t find anything wrong with my car so trying to find a scanner so I can check it myself when the light comes on. I had the engine our service done last year at 25,000 miles so not sure why this light keeps coming on. I appreciate all your recommendations. Thank you.
  5. Qavion
    12,025
    Ian Riddell
    For simply extracting codes, you won't need anything special (regarding OBD2 scanners). We don't have a 355 decoder, but the 360 codes are pretty close.
    https://www.dropbox.com/t/eKo1SFjGvfm8ntqu
    Do you know if you've had the OBD2 wiring modification done (to ground pin 4 & 5)? There was a Service Bulletin for this.
