obd 2 test p1448? | FerrariChat
obd 2 test p1448?
Discussion in '348/355' started by van22, Jan 3, 2008.
  1. van22
    van22 Karting
    227
    Absecon Island, New Jersey
    VAN C
    ran innova obd2 tester on my 98 355 spider the other day and this code popped up and cannot figure out what it is any help would be appreciated. car runs fine. thanks van
  2. ShopBoy87
    ShopBoy87 Karting
    Jun 27, 2006
    82
    Sacramento,Ca
    Matthew H-McCormick
    If memory serves me correctly, a P1448 code will be thrown due to the bypass valve and/or a catalytic converter. From my experience, the code usually resulted in a CEL; however, the light may not be on in your car. Just check for any vacuum leaks at the bypass valve as well as the solenoid for the valve. I'd also recommend checking the thermocouple ECU's to ensure theres no moisture in the connections. All quite simple tasks with the removal of the two lateral panels in the engine bay. Clear the code with your tester when finished and see if it ever comes back. Most of the time that code has had no effect whatsover on the performance of the car. Best of luck.
  3. van22
    van22 Karting
    227
    VAN C
    thanks matt,will do this weekend since its 20 degrees today i'm putting it off till tommorrow it should be in the 40's
