OBD II operation | FerrariChat
OBD II operation
Discussion in 'Technical Q&A' started by dersark_painclinic, Oct 2, 2009.
  1. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    I need advise regarding OBD II operation. reading and erasing OBDII codes engine should be running or ignition should be on only. Thanks for advice. Sark
  2. f355spider
    f355spider F1 World Champ
    18,055
    On my 355 and BMW I have the engine running...this also allows me to read the live sensor data streams, like intake air temp, coolant temp, O2 sensor voltages, etc.
  3. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Do you also erase codes while engine runing. Thanks, Sark
  4. KKSBA
    KKSBA F1 World Champ
    15,303
    SBarbara-La Jolla CA
    KKSBA
    My OBD II scan tool says specifically to NOT run the engine while erasing codes. Just have ignition on.
  5. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Thanks for reply. My OBD III does not come with instruction. I think I should read codes and erase when ignition is on and read the function of other parameters when engine is running. Is that true. Thanks, Sark
  6. fatbillybob
    Aug 10, 2002
    29,255
    socal
    I think there are 2 kinds of OBD readers. One kind just pulls codes which you can erase. They tell you to do that with ignition on only. The other kind obd2 reader will monitor the engine as it is running and pull codes. With these units you can erase codes/pull codes and see engine parameters. So if your machine can see air temps and o2 voltages etc engine on. Pull codes only then ignition on engine off.
    That said I have many times used a "pull code only reader" with engine on with no ill effects.
  7. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    I have used my reader on many different cars with just the ign on to pull codes and erase them. When I used it on my friend's 355, the extra ground connection had to be added to the obd connector and the engine had to be running to read and clear codes. I think the brand is Equus innova. FWIW
    Jeff Pintler
    89 348tb, 86tr
  8. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Where do yous buy your scan tools.....ebay? Actron? Need an obd 1.......
    I ubderstand you use an obd 2 with an adapter cable.....
  9. glasser1
    glasser1 Formula Junior
    Sep 2, 2006
    510
    Oregon
    scantool dot net
  10. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Thanks, Glass, Ill check them out. Hope they dont want $5000 for one, as I heard they go for.
  11. North East Auto Doctors
    65
    conn
    Adam Varney
    the problem is all obd2 readers are not the same i can hook up 5 differnt readers and pull "ghost codes" or multiple differnt codes on the same car, also you cant always trust the data stream take it all with a grain of salt the other problem is that ferrari is not the most obd friendly car since they have such low output they can get away with stiffing the obd regulation. Ferrari does not want you in their cars like that "jerks". but they are not the only euro make that can fall short on the obd side, they were able to skimp on us safety airbag standards with the 430 arguing expensive to our government
  12. fatbillybob
    Aug 10, 2002
    29,255
    socal
    I thought I was crazy but I noticed this too! I could not figure out why sometimes there seemed to be a lack of consistency with code reading. In fact I never trust the codes the first time I get them. I always reset and look again for codes to reappear. I have had the most consistent codes with chevys like 100% accurate. Is the car the problem or the reader? Have you found a reader that seems to be more consistent than others?
  13. North East Auto Doctors
    65
    conn
    Adam Varney
    Nope we are in the same boat on a Ferrari I will plug everyone I own and compare
  14. f355spider
    18,055
    #14 f355spider, Nov 13, 2009
    Interesting, I have used various code readers, both my own and friends, and have always read consistently the same with each one. Is it possible that not having the recall performed on the OBDII plug ground wire might contribute to poor or inconsistent readings?
  15. Skidkid
    Skidkid F1 Veteran
    9,629
    Campbell, CA
    John Zornes
    I am with you, it has worked well for me. BUT I had campaign 148 done because many won't even read the port without the gnd.
  16. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    When I connect the scan tool to the car it says comp 1,2,3,4,5,6,7,comp 8. What are these and which one needs to be choosed. Thanks Sark
  17. North East Auto Doctors
    65
    conn
    Adam Varney
    The campain had to do with Ferrari not following the rules for us obd2 pin connectors they only put a ground wire on one pin either 4 or 5 the their fix was to have us install a pin in the missing hole and with a cheap splice it over to the existing wire on pin 4 or 5. With out it some state emission inspection machines could not communicate.
