OBD-II Reader for 550 ? | FerrariChat
Discussion in 'Technical Q&A' started by mswiek, Dec 23, 2004.
  1. mswiek
    mswiek Formula Junior
    Jan 5, 2004
    332
    Do anyb of you have/use an atermarket OBD-II reader on a 550 or other late model Ferrari in order to read error codes and reset "Check Engine" lights ? If so, which one do you find useful, what codes can be read, and which errors reset/erased ? Thanks.
  2. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    They work fine. Most codes can be read and are generic obd2 codes that are fairly universal for all cars. My scanner came with a cd that I can pull up the 550 and type in the codes. Some codes are manufacturer specific and it won't tell you what the code means but your WSM should.
  3. mswiek
    Jan 5, 2004
    332
    Thanks. Which OBD2 reader/scanner do you have ?
