OBD tools for 456 ? | FerrariChat
OBD tools for 456 ?
Discussion in 'Technical Q&A' started by TZ 750, Dec 15, 2010.
  1. TZ 750
    TZ 750 Formula Junior
    Jul 18, 2009
    912
    I have now a pair (2) of 456 Ferrari,
    one is a 1995-456 6-speed, and
    the other is a 1999 - MGTA.
    I am looking for reccomendations
    on OBD readers / OBD clearing tools.
    Your reccomendations ?
    Thanks, Scott
  2. Barnone 308
    Barnone 308 Formula Junior
    Mar 22, 2004
    432
    canada
    I actually just bought the Innova 3100 OBDII reader from my local parts shop. Paid $150, for it. I plugged it right into my 355, read the codes nicely. The best way to determine what the codes mean is post them on f-chat and maybe someone can decode it for you.
  3. f355spider
    f355spider F1 World Champ
    18,055
    I bought an ELM327 scanner cord that connects to the USB port on my laptop. It came with freeware, and cost all of about $22 on Ebay. Works great. Displays various sensor outputs too, like o2 sensor voltages, intake air temp, coolant temp, rpms, etc. Pretty amazing for what it cost. Obviously with the larger display on a laptop, very easy to read. Just search "ELM327" on ebay and you will see several of them for sale. They even offer a bluetooth version now for around $40. That might be even better.
  4. f355spider
    18,055
    #4 f355spider, Dec 16, 2010
    BTW, any Ferrari built before 2005, needs to have this recall performed, see the attachment. Without having the OBDII plug updated, your scan tool may not work.
    It will be performed free of charge at any Ferrari dealer.
  5. Llenroc
    Llenroc F1 Veteran
    5,563
    Colorado
    Vern
    #5 Llenroc, Dec 16, 2010
    Your '95 is an OBDI system and you probably won't find a scan tool for it. The '99 is a OBDII system and can be read by most after market scan tools.
    The '95 OBDI ECU allows you to read its fault codes and the WSM has the codes in section C to tell which sensors are malfunctioning. The OBDI is less complicated, ie; has fewer sensors and consequently is somewhat easier to diagnose its problems. Also the WSM gives some alternatives to finding problems with sensors by using a volt meter.
  6. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Can you reconcile the codes from the ODBII back to specific Ferrari Error codes or just clear them?
  7. tazandjan
    39,318
    Frenchie- There are lists of codes available as Ferrari service literature, but they are hard to find. Some codes can be reset using and OBD II reader, some cannot.
    The Durametrics tools should fix all that, hopefully, in the next 18 months or so.
    Taz
    Terry Phillips
  8. f355spider
    18,055
    Just read and clear. To interpet, you need this forum to assist. ;)
  9. TZ 750
    Jul 18, 2009
    912
    Good economical solutions !
    Anybody else ?
    Scott
