OBD2 codes and troubleshooting help | FerrariChat
Discussion in '348/355' started by 355VJT, Jan 24, 2017.
  1. 355VJT
    355VJT Rookie
    Apr 3, 2016
    4
    Okay so I washed my car a few weeks ago and the Slow Down Light came on. Heard that moisture in CTU can cause this.
    Turns out I had a broken clamp and an exhaust leak which I fixed.
    Car is a 98 with headers, high flow cats and a capristo bypass valve. Car was running really well with no issues for last year since major service.
    Right now I am getting the following OBD 2 codes:
    P0153 O2 sensor circuit bank 2 sensor 1
    P1449 Catalyst temperature bank 2
    And the following pending codes:
    P0159 O2 sensor circuit bank 2 sensor 2
    P1451 Secondary Air Pump Circuit
    P1448 Catalyst Bypass Valve Circuit
    I have erased the codes once but they came back.
    So what next?
    Do I replace the bank 2 Catalyst CTU? P/N 160454
    I hear these things are problematic.
    Any thoughts would help.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,653
    San Carlos, CA
    Mitchell Le
    Have you tried the dry washes? If all these happened after you washed your car, then we can assume that you got water in a few places.
    1. Remove the side cover in the engine bay
    2. Disconnect the various connectors at the left hand side that go to the 2 O2 sensors and the bank 2 TCU
    3. Blow them out with compressed air to clean any water in them
    4. Might as well repeat on the right hand side
    5. Crawl underneath the car, right hand side, behind rear wheel well
    6. Disconnect TCU connectors, one et a time, and blow them out with air
    7, Disconnect the 2 connectors controlling the bypass valve and injector valve, Blow those out with compressed air
    Reset, drive, and see what happens
    You may need to replace O2 sensors on bank 2 and TCU on bank 2, especially if it is still the black one.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Unless your O2 sensors are installed in such a way that they point up, I doubt you have water in them but anything is possible.
    I wet wash my car constantly and have no issues.
  4. WATSON
    23,893
    WI
    Are the CAT ECU's black or green? If they are black, they are old and may have been cracked prior to the washing. Green ones may now be required.
    I wash my car form time to time and have driven ion rain a few times as well without issue....but I swapped all three CAT ECU's to new ones 4 years ago.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If you plan to replace the TCU's, I'd suggest you install the aftermarket ones made by Goth and sold thru Ricambi.
  6. yelcab
    Nov 29, 2001
    13,653
    San Carlos, CA
    Mitchell Le
    Water in the O2 sensor connectors to the engine harness, left hand side, mounted to the upright member of the subframe.
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Sorry, Mitch - I missed "connectors" - thought you were talking about the actual sensor...
  8. 355VJT
    355VJT Rookie
    Apr 3, 2016
    4
    Thanks everyone for all the suggestions - will keep me busy this weekend.
  9. 355VJT
    355VJT Rookie
    Apr 3, 2016
    4
    Thanks everyone for all the help - it will keep me busy this weekend
  10. 355VJT
    355VJT Rookie
    Apr 3, 2016
    4
    Thanks replaced the CAT CTU and erased the codes and that did the trick.
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    That's great but don't crack open the champagne yet - you need to clock some miles to be sure the codes won't reappear :)
  12. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    FWIW, I had one of the small hoses to the expansion tank start leaking. After I replaced the hose, I washed off the spilled coolant on the front of the motor, to get the coolant off of the belts. Every time I would go around a hard right turn the engine would stumble and throw a light, and after a few seconds it would go away. It turned out to be the connector at the crank sensor. It was filled with water/coolant! My cats and Ferrari dont enjoy baths.
