360 - OBD2 Not working? | FerrariChat
360 OBD2 Not working?
Discussion in '360/430' started by THE VATICANTS, Apr 30, 2023.
  1. THE VATICANTS
    THE VATICANTS Formula Junior
    Feb 5, 2020
    299
    Los Angeles
    VATICANT
    I have an engine light on the 360, probably nothing as usual. I use an Innova 3011obd2 which worked fine on the 355 but when I connect to to the 360 nothing happens. I know I have to turn the ignition on (not start the car).
    The connector on car is fine as the car was just in shop and the code reader is also fine as I tried it on the Hyundai just to make sure it didn't die.
    Any thoughts?
    Thanks.
  2. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    Immobiliser disarmed?
  3. THE VATICANTS
    Feb 5, 2020
    299
    Los Angeles
    VATICANT
    How would I be able to check if it is?
  4. Qavion
    14,259
    Ian Riddell
    Does the LED near your left knee stop flashing when you push the fob button? Key on immediately after pushing the button or, if the 360 allows it, push the fob button with the ignition key already on.
    This is assuming you haven't had an immobiliser delete modification done to your car.
    Surely you went through this procedure with your 355?
    THE VATICANTS likes this.
  5. THE VATICANTS
    Feb 5, 2020
    299
    Los Angeles
    VATICANT
    yeah the light stops flashing right after I deactivate the alarm. Strange, car won't trigger the obd2...
  6. Qavion
    14,259
    Ian Riddell
    #6 Qavion, May 1, 2023
    On my F355, I seem to recall that I had to turn on my scanner after I had disabled the immobiliser. I have an Innova scanner, too.
    Has your car had the OBD2 port wiring update? It seems to affect some scanners on some cars. i.e. there should be a spliced black wire at the back of the OBD2 port. It's spliced with a red(or brown?) "Scotchlok"
  7. S F
    S F Karting
    May 13, 2016
    167
    Texas
    Any fuses blown? I seem to recall it’s on the same circuit as either the cigarette lighter or the lights in the door/glovebox.
    Qavion and THE VATICANTS like this.
  8. Qavion
    14,259
    Ian Riddell
    Also the dome light.
  9. THE VATICANTS
    Feb 5, 2020
    299
    Los Angeles
    VATICANT
    funny enough, you're right, the cock, glove compartment light and light next to clock are out. Can I fix this myself?
  10. THE VATICANTS
    Feb 5, 2020
    299
    Los Angeles
    VATICANT
  11. Qavion
    14,259
    Ian Riddell
    #11 Qavion, May 2, 2023
    Replace fuse and pray that you don't have a short somewhere :D
    It's a blue, 15 amp fuse
  12. THE VATICANTS
    Feb 5, 2020
    299
    Los Angeles
    VATICANT
    Where can I get these fuses? Are they generic?
  13. Qavion
    14,259
    Ian Riddell
  14. THE VATICANTS
    Feb 5, 2020
    299
    Los Angeles
    VATICANT
    OMG I DID IT lolllll. It was the 15 fuse, and thanx to you all I fixed it, the four beep sound is gone, clock is on, obd2 works now, glove and dome light is on. Thnx @quavion for the fuse chart that made the difference. I was about to order a fuse then, CAN YOU BELIEVE IT, I THOUGHT TO MYSELF WHY NOT CHECK IN THE FERRARI 23 YEAR OLD TOOL BAG LMFAOOOOOO AND SURE ENOUGH THERE WERE FUSES IN THERE! HAHA WHEN HAVE YOU EVER THOUGHT THAT TOOLBAG WOULD ACTUALLY SAVE THE DAY!!!!!!
      File size:
      129.1 KB
      68
      File size:
      125.3 KB
      63
      File size:
      64.3 KB
      62
      File size:
      31 KB
      62
      File size:
      49 KB
      63
      File size:
      44.4 KB
      63
    Mel Spillman, Qavion and S F like this.
  15. priericky128
    priericky128 Formula Junior
    676
    St. Louis MO
    Rick
    I have used my toolkit too. I also found it hilarious when doing so.
    I was also like well don’t you know it does serve a purpose other than being a paperweight.
  16. Qavion
    14,259
    Ian Riddell
