OBDII Connection for Euro F-355 | FerrariChat
Discussion in '348/355' started by Sheldon Rubin, Feb 16, 2009.
  1. Sheldon Rubin
    Sheldon Rubin Rookie
    Jul 10, 2006
    37
    The connector on my 355 not located under the dash near the steering column. Instead it is located behind the access panel that is behind the driver's seat. But the connector is different than the mating connector on my diagnostic reader. Is there an adapter cable that interfaces between the OBDII and the connector on the dangle-cable connector located under the access panel? Where can I find out where to get one? Stumped, so any suggestions would be appreciated.
  2. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    #2 eric355, Feb 16, 2009
    US cars have the famous OBD connector somewhere in the dash. On euro cars, there is NO such a centralized OBD connector but you will have to connect to the one which is close to the Motronic behind the right seat. You can use it without any problem with any reader. You just need to connect 3 wires from your I/F to the 3 pins AMP connector. The pin function of this connector (K, L and ground) can be seen on the pictucture. The pin correspondence between a generic OBD connector and the 3 pins AMP connector is the following:
    Left pin to OBD plug pin number 15 (L line)
    Middle pin to OBD plug pin number 5 (signal ground)
    Right pin to OBD plug pin number 7 (K line)
    You can either build a small piece of cable to do this connector adaptation, or cut the cable of the reader and install a male 3 pins AMP connector (available in car stores). You will also need a power supply (+12V) which can be taken from the cigaret lighter.
    Once you are connected it should work with only ignition on ... but with alarm de-activated (LED not blinking!). No need to start the engine for DTC reading but of course yes for live data monitoring.
  3. Sheldon Rubin
    Jul 10, 2006
    37
    Thanks for info. I will make up an adapter cable.
  4. hacker-pschorr
    hacker-pschorr Formula Junior
    Sep 27, 2006
    584
    Land of Lambeau
    eric355 (or anyone else...)
    Is that connector behind the seat the same on US cars? I understand the US cars have the "standard" plug under the dash, just curious if the ROW connector behind the seat is the same for US cars.
  5. fatbillybob
    Aug 10, 2002
    28,989
    socal
    Some euro cars do not give the data output the usa cars do either. OBD2 is usa IIRC not rest of the world. So then you got to have the SD2/3 to see what is happening. The negative is you don't get some data. The positive is that the mil light does not come on as often for little stuff that would make you fail smog in places like the people's republic of california
  6. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,683
    LA & OKC
    Kevin
    Where is the connector under the dash for US cars, maybe I'm retarded but I can never find it.
  7. Lagerlout
    Lagerlout Formula Junior
    Jan 5, 2006
    468
    West Sussex, UK
    Mr. LL
    Bumping an old thread, does anyone know a source where I can buy the pictured AMP connectors? I found similar ones online, superseal but they have a yellow coloured seal and totally different pins. Not your typical round pins. Seem to have been on every electronic website in the world and still no luck.. Help?!
  8. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    I bought my connector from this company a while ago
    http://www.autoelectricsupplies.co.uk/
  9. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    #9 eric355, Apr 21, 2009
    Sent you a PM some days ago with the same address for that connector. The pins are not round but flat and about 1mm large.
  10. Lagerlout
    Jan 5, 2006
    468
    West Sussex, UK
    Mr. LL
    Eric, thanks, I did get the PM and bought these connectors. I must be going senile as I could swear the connector in my car has round pins. Will have to double check or maybe I'm looking at the wrong connector. It's the free cable under the RHS panel when sitting in the car yes?
  11. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    Yes, it is the free connector close to the Motronic, under the cover behind the right seat
