Occasional no start | Page 2 | FerrariChat
Occasional no start
Discussion in '348/355' started by Nader, Nov 21, 2016.
  1. Qavion
    Qavion F1 World Champ
    14,620
    Ian Riddell
    Not sure why you're having problems finding it, but depending on the age of your car, it could be a 9-pin circular type or a rectangular, rubber-booted 10-pin type. But it's right behind and slightly below the top of the left hand rear shock strut. I recall the circular type is mounted in a hole in a metal bracket.
    Here's a picture of the newer harness (not showing the location, but the plug)
    https://www.ebay.co.uk/itm/Ferrari-348-348tb-348ts-MOTOR-UTILITIES-CABLE-WIRING-LOOM-HARNESS-151912-/292595612811
  2. Qavion
    14,620
    Ian Riddell
    #27 Qavion, May 4, 2020
  3. Qavion
    14,620
    Ian Riddell
    .... or I may have assumed that the plug was in the same location as on the F355
  4. m.stojanovic
    m.stojanovic F1 Rookie
    3,314
    Serbia - Niš
    Miroljub Stojanovic
    JM280z, ernie and Wade like this.
  5. Jasonberkeley
    Jasonberkeley Formula 3
    1,348
    NW Corner, CT
    Went for a 30 minute drive last night, and problem appears to be resolved since cleaning the bullet connector. Pulled into garage, shut it off, immediately restarted with no problems. Let it heat soak for a few minutes, also restarted. Im tracking the car today at Lime Rock, so will get much hotter today than last night. I'll report back if any issues.
    Qavion and steved033 like this.
  6. Jasonberkeley
    1,348
    NW Corner, CT
    So after a long session on track, then letting car heat soak for awhile, car did the same thing and wouldnt start. Seems to only happen when the radiator fans come on when you turn the key to accessory. Any thought other than getting a one piece cable and ditching the bullet connector, which I will do shortly?!
