Occasional Strange Noise while Shifting | FerrariChat
Discussion in '360/430' started by Aloha Ferrari F430 Fl, Apr 16, 2016.
  1. Aloha Ferrari F430 Fl
    Nov 8, 2015
    32
    BC, Canada
    I was driving my 2007 F430 F1 this afternoon, while enjoying a nice ride on a sunny day, going up the mountain I geared down from 4th to 3rd so I can enjoy the sound of the engine as I made the turns, the car made this strange noise, it felt like s sheets of metal smashing each other, it lasted for 1 or 2 seconds. The car continued to drive fine, no alarms came on, all pressures were normal. I continued driving for 30 more minutes and then it did it again but much lesser noise than the first time, going from 2nd to 3rd. I drove for another 30 minutes and it did not do it.
    When I got home, I put the car in the garage and few hours later I checked underneath it, no sign of oil drops or any damage.
    I appreciate any help or guidance from the members.
  2. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    Not a lot to go on, but depending in your mileage I wonder about motor mounts. My car did som things goring hard cornering that I did not know we're due to broken mounts until after I changed them.
  3. Rifledriver
    37,072
    Since both time it involved shifting into the same gear you need to consider the possibility of a 3rd gear syncro issue. F1 transmissions make an unusual but characteristic noise when syncros are failing.
  4. Aloha Ferrari F430 Fl
    Nov 8, 2015
    32
    BC, Canada
    Thank you for the reply, the car has 14,500 miles. If it is a 3rd gear syncro issue, is it expensive to fix? Can I drive it to the dealership?
    Can this noise be the headers? My dreaded fear.....
  5. Rifledriver
    37,072
    Not if diagnosed and repaired by the right guy. Very expensive by the wrong one.
    Yes.
    Why? Anyone can properly diagnose and repair a bad header. The wrong guy on the transmission will be a lot more money. I have seen many just sell a new trans due to their inability to diagnose and fix them. That will be a bad day.
  6. Aloha Ferrari F430 Fl
    Nov 8, 2015
    32
    BC, Canada
    Thank you Rifledriver, if it is a syncro issue, would it do it all the time or can it be occasional? The reason I am asking is that it did it only twice in about 2 hours drive although I shifted a lot to and from 3rd gear frequently to replicate the incident.
  7. Rifledriver
    37,072
    In early stages infrequency is common.
  8. Aloha Ferrari F430 Fl
    Nov 8, 2015
    32
    BC, Canada
    Is it very expensive to fix? Is there a lot of labor involved in fixing it? I am not mechanically savvy at all and will end up doing what the dealership says to do, so any advice on that front is appreciated.
  9. Rifledriver
    37,072
    Not a big job for the right guy. Huge job for the wrong one.
    75% of the shops out there will estimate time for complete overhaul. Actual time required about 25% of that.
    Do not put cart before the horse. It is not diagnosed yet.
  10. Aloha Ferrari F430 Fl
    Nov 8, 2015
    32
    BC, Canada
    Rifledriver, thank you for the support. Much Appreciated.
