360 - Odd sound coming from pulleys | FerrariChat
360 Odd sound coming from pulleys
Discussion in '360/430' started by 550nitis, Dec 11, 2023.
Tags:
  1. 550nitis
    550nitis Formula Junior
    761
    Houston
    Getting this weird noise from the drivers side of engine, feel like it's a tensioner, pulley or a belt. The sound is intermittent and is after the car has warmed up and then driven at a low rpm. The sound doesn't get louder with higher revs or speed. I just can't seem to replicate it once I get to the shop.
    I've had two shops look at it and both say the tensioner pulleys are fine and find nothing.
    Ufffffffff.
  2. 550nitis
    761
    Houston
    Thought it was the hydraulic tensioner or some other pulley. The full major was done only two years ago.
  3. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Ac comp?
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,955
    Central NJ
    Dominick
    The thing that got me is that the noise doesn't change with Rpm
    Can you post a sound clip
  5. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    Agree with Dominic if it doesn’t change with engine rpm can’t imagine it’s a pulley. Also does the car have to be moving? if so then prob look elsewhere.
    Does it happen with the ac on (windshield defroster will engage ac)?
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,955
    Central NJ
    Dominick
    Could it be a fuel pump
    EastMemphis likes this.
  7. 550nitis
    761
    Houston
  8. 550nitis
    761
    Houston
    That could be but I thought that was more of an air sound?
  9. 550nitis
    761
    Houston
    The car needs to be moving but doesn't change with rpm. The shop confirmed the pulleys belts are all good. Have to look else where!
  10. 550nitis
    761
    Houston
    Just put a video link bellow!
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,955
    Central NJ
    Dominick
    very hard to tell ... at first I thought TO bearing .. but you say it doesn't change in rpm / speed
    Could it just be a rattle from one of the exhaust clamps ..
    Air pump .. but that should be off after warm up
    Sorry .. hard to diag over internet
    Best bet - buy a stethoscope from harbor freight and poke around .. you will find it in a few minutes - use the cone tool first to isolate area and then metal rod to pin point it
  12. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    For some reason I can’t access the clip.
    Only happens when car is moving so will be hard to use stethoscope.
    Will it happen if rolling in neutral?
    If so What about if you shut the car while rolling in neutral?
  13. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    I was able to listen, forget my last post, clearly happening when not moving.
    I agree with Dominic try a stethoscope. Have you tried turning off the heat/ac, the ac compressor is on that side. Push the stop button.
