Odd Starter problem ??? | Page 2 | FerrariChat
Discussion in '348/355' started by Night life, Jan 23, 2009.
  1. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    According to a quick look at the wiring diagram, the "control relay for key operation" (relay e), supplies power to fuses 5,6, and 7. It is not part of the starter circuit.
  2. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    #27 MaterMech, Jan 30, 2009
    I had/have the same click no start issue. I took the starter solenoid appart and found one of the contacts was cocked slightly causing only a point contact. I loosened it and shoved a washer under it to keep it flat and then re-torqued it. It of course did not fix the click but I slept better knowing the starter and brushes were healthy. I checked the solenoind wire conection on the left rear frame for corrosion and found none. It started when I measured voltage behind the ignition switch but I'm liking the idea of the added relay.
  3. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    #28 PAP 348, Jan 30, 2009
    Just do it yourself mate, thats all I did. Took around 1 hour from start to finish. :D:D
    Here are some pics. I have a "write-up/instructions" here somewhere. ;);)
  4. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    #29 MaterMech, Jan 31, 2009
    Genius Pap, your welcome on my gold dredge anytime! :)
  5. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Lol! Thanks mate! :D:D
  6. Night life
    Night life F1 Veteran
    7,325
    The city that rhymes with fun in Canada
    Roberto
    Thanks for all your help fellows..:)
    I finally had some time today to play with my mistress so after checking the battery twice the ignition switch and some of the relays I decided to do what was suggested and override the switch and go straight to the starter. As I was checking the connections by the starter the main positive lead seemed a Little loose not much mind you so I tightened it a bit tried it still nothing but it sounded different than before so I knew I was on to some thing I disconnected the lead cleaned the connections re tightened and voilà she fired up like a champ WOO HOO....:)
    Problem solved.
    Let me tell ya there is nothing like hearing that motor fire up I was on a high all day long.
  7. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Very good to hear mate! :D:D
  8. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Ditto.
